MAC H PIPE has cancer
is it rusted at the cross over? Mine rusted right out right there. I just replaced it with an X-pipe. I couldn't be happier, it sounds so much better, and it's quiter (from the inside of the car at least...)
Mine did the same thing. I took a piece of 2 1/2 pipe, a die grinder and a cut off tool and made a sleeve that fit over it perfectly. Then I had the muffler shop weld it up. The muffler shop tech was surprised; he said he had never seen such a thing. The fit was excellent and I saved buying a new Cat H pipe.
stang2841 said:
well mac as a whole is a piece of ****
they rust like hell most of there products
You get what you pay for. Generally, MAC products are at the low end of the expensive scale.
FWIW, my MAC headers have been on my car for about 9 years and have no rust to speak of, just the "bluish tint" that appeared shortly after installation. Other than that....no problems.
YMMV...I'm sure depending on where you live (snow, etc), rust may be more of an issue...
my BBks are doing really good. someone posted one time about only certain X-pipes had a correct flow to be beneficial. not sure of that info but something to check out. Bassani are nice but hella high. thats what i am going to use i rebuild. i think, unless i get cheap on myself.
Mark89Notch said:
I HAVE A MAC H PIPE THAT IS RUSTED BEHIND THE CATS. THE PIPE STILL LOOKS NEW. ARE THESE KNOWN TO RUST? WHAT BRAND SHOULD I REPLACE THIS H PIPE WITH? THANKS :confused:
call mac they will probally replace them if you are the original buyer
all h-pipes & xpipes except stainless are made from aluminized steel i have macs new 3 piece pro chamber with cats
on my 02 gt it has new black coating plus being aluminized runs great!
