mac lt headers?
94opalgt
358
AKRON,OHIO
does anyone have a pic of the 1 5/8 mac lt's with a 2.5 collector?or if you have these,is it a pain in the a$$ to change the plugs?i looked at bbk's and there aint no way in hell those are going on my car,looks like you would have to pull the header off to change the plugs.i know there equal length shorties suck to change the plugs.i went to the mac site and the only pic they had were the 1 3/4 with hts coating.what the hell is that?paint.any help here?the only way im gonna go with the bbk's is to try the 1 3/4 lt's for the fox cars.:shrug: :bang:
I don't have any experience with the MAC LT's. I DO have the BBK LT's on my car and all I can tell you is it's easier to change my spark plugs now then it was with the stock headers.
I have the pro-chamber and in all honesty, I wish I would have done the h-pipe. Sounds better in my opinion. The h-pipe has the rumble that distinguishes the mustang. The pro sounds good but is not as loud(throaty) as the h-pipe. Also, i don't think that the x's sound too good on our cars. They sound wicked on 4.6s but not on 5.0s.
I have the Mac LT's :D
No probs with the install, fit, or since the install over 3 years ago.
I've done nothing but snug the bolts after a couple heat cycles.
Ed Curtis told me a stock block h/c/i combo would loose torque with the larger 1 3/4 size :(
Just not enough airflow gets produced I would imagine for the larger size and we are talking about NA btw :)
Grady
I have the 1 3/4 Mac's No issues. Plugs are as easy to change as they where stock. I have the 3" collector and Prochamber. I am not as fond of the sound but I am not complaining of the power. Plus I don't need it any louder.
I snug my bolts when I change/check my plugs.
I think MAC has improved their quality a good bit. My finish is nice fit, was excellent. Of course it all wendt in at one time and I had to clearance for the Lakewood Bell.
thanks for all your help,and for the pix.and for the info on the pro chamber vs h-pipe.i think i'll go with the h.im trying to get this car over 300hp with a stock cam.im sure grady remembers this.i'll let you know if i do,i'll post numbers.thanks for the info on the 1 3/4 also grady.
with all the smog crap out of the way, loosen the motor mount and jack the motor up several inches. at that point, the passenger side should go in from the top after unbolting the starter. the drivers side, i went from the bottom after jacking the motor up slightly and disconnecting the steering shaft. the install isnt as bad as some people say it is.
from what i have read,you do have to go from under the car.but i got no a/c or smog stuff so i am gonna try and see if i can get em in from the top.we'll see though,i doubt it.also thinkin of droppin it off @ the local shop and havin them do it for me.
final5-0 said:
If you wait until you have the motor in a heads off condition, the LT's can literally be laid in place :)
No Muss ... No Fuss :banana:
Grady
Reallllllyyy????? thats good to know, im about to buy me a 94-95 so ive been doing some homework since im a fox guy.. Ill wait and do it alll at once! thanks final5-0! :nice:
