Timeless2, Propellerhead. Thanks for your help you were both right on the money. I had to use the adapter piece. Just came in from getting it installed. Once I started fitting it up I saw that the drivers side exhaust manifold studs were stepped and that with out the adapter I was going to bottom out the nuts before it tightened up. This is really a Nice Piece. Great Fit. No leaks and easy to install. I scotch brighted all the ball ends and sockets. Cleaned up all the burrs on the ball ends. I used the flange gasket that Mac included with the pipe because the original gasket wouldn’t work because of the raised area at the inside of the original gasket. I gave the flange gasket 5 good coats of Permatex Copper sealant I also coated all the ball ends with 3 good coats. I also coated the adapter piece on both sides with it. It made a good lubricant when I was tightening it up. The 3 piece design was alot easier to deal with than my previous pipe. It had a slip joint, I could never get it to fit right and I always had an exhaust leak. Finally a project that went smooth. Thanks again for your help.
