  • SN95 4.6L Mustang Tech
Mac Prochamber with cats??
  • Thread starter Thread starter mity2
  • Start date Start date May 3, 2004
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
May 3, 2004
  • May 3, 2004
can it be done? I mean is there enough room to weld(or Cramp) cats in them?
has anyone done this?
Dark Knight GT
I can't get it up......ok that didn't sound right.
May 26, 2003
3,653
Ozark, Missouri
May 3, 2004
  • May 3, 2004
Yes, it can be done. My signature should explain it all. I would use Mac cats with the prochamber if you decide to put cats on it. They are smaller than most converter and would probably work best with the prochamber.
85GTlover
704
  • May 3, 2004
I would think if you look at pictures and it looks possible, as in they look like they will fit and still be the same length in the end, it should be possible but, if they are not sold in public, either they will be, or the benefit the prochamber has over a catted X or anything for that matter, would be lost when you add cats to the prochamber. Maybe not but.... I did not see the above post, it took me THAT long to answer.
V
VatStang
88
Santa Clarita, CA
May 3, 2004
  • May 3, 2004
What is the prochamber? Is it like and X or H pipe connection? Is it an off road application? Enlighten me.
85GTlover
704
  • May 3, 2004
It is like a box instead of the h or x, pipes go in one end out the other As for inside of the box But it is supposed to be better than both. I assume offroad thus the other questions about putting cats on, but like it says above you can get it done. I do not think you can buy prochamber with cats, maybe, its a big world, but generally no.
Dark Knight GT
May 26, 2003
3,653
Ozark, Missouri
May 3, 2004
  • May 3, 2004
The prochamber does not come with cats. You have to buy them seperately and have them welded into place. This is pretty expensive too. The cats alone with installation costed me about 300 dollars. Not to mention the price of the prochamber.
mity2
Jul 24, 2003
2,872
StateCollege PA
May 4, 2004
  • May 4, 2004
300 bucks? I was thinking of getting Magnaflow Highflow cats, and just cramp it in. I can get magnaflow cats for 57 bucks each, and if I choos to weld it in, my friend has mig welder, So I figured it'll cost me around 350~400 bucks or so...
Unless ofcourse, i can find magnaflow catted X for 350 or so...
Dark Knight GT
May 26, 2003
3,653
Ozark, Missouri
May 4, 2004
  • May 4, 2004
Well, the magnaflow cats would probably work. I've seen them before and they will fit. I had to choose Mac's though cause of the Long tube header installation I was limited to room with the cats. You can probably find a Magnaflow catted x-pipe for under 400 bucks, Im sure of it. Check on E-bay and do an internet search.
C
Need MIL Eliminators?
  • crazyone64
  • May 18, 2026
SN95 4.6L Mustang Tech May 21, 2026
GOvert
G
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
Engine Cleaning Intake valves with lower intake off
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 11, 2026
limp
Resolved Three way cat converters..?
  • PonyGTrider
  • Nov 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 2, 2025
PonyGTrider
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
