- Mar 30, 2007
- 25
- 0
- 0
Hey I was just wondering if anyone has had to change the clutch on their 03 or 04 Mach's yet...are these clutches very strong and up to par for a little racing? I just got mine and it only has 10,000 miles on it. 04. I was pretty much giving the car a good test run today for about an hour worth of ripping into second and even fishtailing 3rd gear. (the ground was slightly damp). Other than that I dont drive her hard and I never use the clutch unless Im shifting. I didn't WOT and I never wait on the clutch at lights or stop signs. Just a little hard gear chirping fun. Do I have anything to worry about?
---------------Part 2
Does anyone else notice that their Mach idle comes down very slowly. For example I'm in 2nd gear at 3 RPM and I put it back into neutral. The needle slowly drops from 3 back down to 1 and then below 1. I feel it should it should be dropping more quickly though. Is this normal because of clutch and flywheel weight, or is something wrong with my car? I just got it 4 days ago. Also today after my gear chirping episode at one point for about 3 minutes when I was in neutral and then came to a stop, the idle stayed at about 1,300 RPMs, when normally it drops to about 700. Do all machs do this??
. They should at least be 17-9. If I stuck with the Mach wheels I would have gotten the billet vintiques Magnum 500's in 17-9 & 17-10.5 with 315's in the back or deep dish Mach 1 style wheels.
