  • SN95 4.6L Mustang Tech
Mach 460 Question
  • Thread starter Thread starter LaserSVT
  • Start date Start date Aug 18, 2007
LaserSVT
3,548
233
Aug 18, 2007
  • Aug 18, 2007
Have a few tech questions for the Mach 460 system in the 94-98 cars. I need to know what is the low pass x-over point going to the door speakers, and is their a high pass signal comming from the stock amp to the stock door tweeters, and if so at what frequncy, or does it only use the cap attached to the tweeter?
LaserSVT
3,548
233
Aug 19, 2007
  • Aug 19, 2007
Did I stump everyone?
Mossberg
ATL, Shawty
Aug 19, 2007
  • Aug 19, 2007
I believe the separate tweeter amp under the dash is crossed over inside of the amp itself and doesn't use an external or in-line crossover.
larrendeuce
649
Southern NJ
Aug 19, 2007
  • Aug 19, 2007
The tweeters are 300hz and up, doors are 300 hz and below. The woofers aren't wired in stereo, the tweeters are.
LaserSVT
3,548
233
Aug 19, 2007
  • Aug 19, 2007
Thanks, helps alot! Where were you able to find that info?
larrendeuce
649
Southern NJ
Aug 20, 2007
  • Aug 20, 2007
Someone very knowlegable wrote a whole thread about how the mach system is wired and its specs. Its much more in depth then the common info websites that people often link to. I'll see if I can find it and post a URL.
LaserSVT
3,548
233
Aug 20, 2007
  • Aug 20, 2007
Thanks, I appreciate it I would like to leave the factory stereo and just enhance the sound a little. The previous owner put Lanzar 6x8 in the door and they have no mid bass, but they are hooked up to the tweeter wires. He also put Lanzar tweeters where the factory one were. I cant put anything up there that can handle 300hz and up so I am trying to figure out what I want to do I guess I can get a three way component system and use the 300hz and down signal to feed some 6.5's and put 5.25 components in the kick panels, but I want to keep it simple. Mabey I can just find some factory speakers.
larrendeuce
649
Southern NJ
Aug 20, 2007
  • Aug 20, 2007
Factory speakers would be your best bet if the system hasn't been cut up too much. I have read people think the mach 460 sucks, I drove a 2001 GT with the mach 460 and it didn't sound good, but the system in my 04 Mach 1 sounds great, wouldn't trade it for anything. I think age and use have alot to do with how good it sounds. Going with some new speakers should make it sound good again. Aside from that, you best off removing every mach 460 component and starting fresh. It is a pretty complicated audio system compared to almost anything aftermarket and it doesn't work well with non stock components.
Adding subs with mach 460 system
  • 2v.cjmullis
  • Sep 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2026
gkomo
Stereo snakes nest; what am I missing?
  • Scott_S
  • Aug 29, 2025
  • Mustang Sound & Shine All
Mustang Sound & Shine All Sep 24, 2025
Scott_S
K
Need help with 99 cobra mach 460 audio
  • kevinatd18
  • Mar 16, 2024
2K
Mustang Sound & Shine All Mar 17, 2024
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
