mach1 motor is this a good set up
mach1connor
MMR 5.0 STROKER Street Mod 850 (up to 850HP) 2V, 3V or 4V
(all) 4.6L/5.4L 4-Valve COMP CAMS Stage III Camshafts pn CCA-106500
FMS Ford 98-04 Mustang COBRA /MACH-1
- Ford Racing High-Flow 4.6L DOHC Cylinder Head
- CNC ported to increase flow and performance
- Assembled with 2004 Cobra production springs, valves, retainers, locks, and seals pn
FMS-M-6049-464P,FMS-M-6050-464P
1711
03-04 65mm Throttle Body - Mach 1 & Bullit
c&l cai with 85mm maf
long tubes
off road x
I don't know man. It's still a mod motor, and they aren't known to produce a lot of horsepower normally aspirated, without some pretty sophisticated porting and machining. My guess would be that setup would net about 375-400hp, maybe, unless I'm missing something, because I don't see a magic bullet there that is going to produce bundles of horsepower.
I would say that 12k would be better spent on an Aluminator long block, either N/A or S/C, and top it off with the blower of your choice, either a Whipple, KB, or Procharger, and have a motor easily capable of 600-700hp.
its going in this weekend i will let u know what it makes
How is it going with the setup?
I'm running the same cams in a 99 Cobra
- Comp Cams XE278AH #106500 w/intake cams advanced to 108 C/L with the recommended valvesprings.
- 30lb injectors.
- Pro M meter calibrated for 30lb and CAI.
- BBK twin 65mm throttle body.
- Aluminum flywheel with Centerforce DF.
- 4.30 gears.
- March underdrive crank pulley.
- BBK cold air intake.
- Minor porting of the intake.
- Full length header/off road X-pipe and 3 inch Cat-Back with bullet mufflers.
Tuned with Sniper Special Forces
