  • 2.3L (N/A & Turbo) Tech
Mad as heck.... '87 won't start... Again!
  • Thread starter Thread starter 87LX2.3
  • Start date Start date Jun 22, 2009
87LX2.3
51
Central Iowa
Jun 22, 2009
  • Jun 22, 2009
You guessed it....
If you're reading this, you are reading yet another post about my miserable $300 Mustang.
Today:
Got home from school, decided to take Mustang to auto parts store to do in-car alternator check. As always, you have to jumpstart it, because the battery will have died since the last time I drove it. So, I get it hooked up to my other car, climb in, and (most of you can guess what happens next) it wouldn't start! I checked for fuel (yes), spark (yes), and that all the hoses/lines were hooked up (yes). I let it sit there a while to let the battery charge using my other car. Climbed in again and, no start. Same as always, the darn thing cranks over perfectly.
If I haven't already taken your ideas, I would love to hear from you as to what you think the problem is with my car. Thanks!
robbo1987*2.3*
445
varina, va
Jun 22, 2009
  • Jun 22, 2009
tfi module or pickup in distributor
87LX2.3
51
Central Iowa
Jun 22, 2009
  • Jun 22, 2009
Thank you robbo1987*2.3*!
I have already replaced the TFI. It will start sometimes, so could the pickup coil in the distributor have an intermitent dead spot in it?
apollo12
155
port st.lucie fla
Jun 25, 2009
  • Jun 25, 2009
could be the coil or the computer may be on the way out ,did you pull the codes?
robbo1987*2.3*
445
varina, va
Jun 25, 2009
  • Jun 25, 2009
naw
the coil is on the strut tower on the driver side there is a pip ( profile ignition pickup) inside the distributor that works in conjunction with the tfi. just swap out the whole distrbutor i have never had any luck trying to pull them apart to replace it. the computer is a possibility that should be easy to find.
87LX2.3
51
Central Iowa
Jun 26, 2009
  • Jun 26, 2009
Thanks you guys,
I'll just plan on replacing the whole distributor and maybe that will take care of it.
O
oh9mustang
Banned
Jul 27, 2008
138
  • Jun 27, 2009
ENGINE CONTROL MODULE
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Sep 13, 2026
Mcmahst
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Saturday at 5:19 PM
manicmechanic007
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
D
sad day
  • davecobra2
  • Jul 13, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jul 22, 2026
davecobra2
D
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
