  • 1994 - 1995 Specific Tech
Mad Detonation! Need To Fix Quick!
  • Thread starter Thread starter skylovia
  • Start date Start date Apr 16, 2005
skylovia
66
  • Apr 16, 2005
Guys this one is really bad! Even on 91 octane gas and my timng set at about 5 degrees, im getting really bad detonation when i get on the the throttle, its REALLY bad over 2500. Could a bad MAF sensor be messing with my air/fuel mixture causing detonation? I'm at a loss here cuz i just tuned up the car last week(cap, rotor, plugs-Autolite 24), Its really pissing me off too cuz i cant drive fast at all. Any help will be much apreciated.
HISSIN50
34
129
Apr 16, 2005
  • Apr 16, 2005
seems like cleaning the MAF wire, ECT and ACT can help. for right this second, you could try locking out the timing at like 20* and see how it does.
what temps are you running (if you have a real gauge and know).
good luck.
HISSIN50
34
129
Apr 16, 2005
  • Apr 16, 2005
oh yeah, if it happens only at higher revs and deeper in the pedal, i would not overlook lack of fuel (filter, pump, bad regulator, etc).
good luck.
skylovia
66
  • Apr 16, 2005
My pump is whining a lot Bout time for a new pump i guess, would a 190 be a good idea since its gonna stay stock for a pretty long time?
HISSIN50
34
129
Apr 16, 2005
  • Apr 16, 2005
um, probably a good one - i cant remember what stock is (on my 88, the stock pump was like 88 LPH and i think that was bumped up to around 95 LPH for SN's). in any case, that should work pretty well, i think. others might disagree.
i would troubleshoot it a little more before figuring it is the pump though. a FP gauge will tell a lot. good luck.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Apr 17, 2005
  • Apr 17, 2005
Yeah, start with the basics. Check vacuum, fuel pressure, plugs/wires/cap/rotor, clean MAF and IAT, check resistance at IAT and ECT, replace fuel filter (if it hasn't been done in a long time), etc.
Does your car ping at WOT only, or part throttle, or both? Test WOT and part throttle when the motor is bone cold (1st 60 seconds of from startup time) and nice and warm.
Scott
rude_life
372
  • Apr 17, 2005
Dude disconnect the negative battery terminal, take apart the MAF housing and clean that bad boy with some rubbing alcohol GENTLY. Works wonders man
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
W
Resolved Loss of Horsepower After Base Idle Reset??
  • WTW
  • Aug 12, 2023
2K
Fox 5.0 Mustang Tech Aug 13, 2023
WTW
W
Idle and power issues on my '95 Cobra (codes inside)
  • 02 281 GT
  • Jul 8, 2021
3K
1994 - 1995 Specific Tech Jul 11, 2021
02 281 GT
