Made a custom console and sub enclosure
  • Thread starter Thread starter 68converted
  • Start date Start date Mar 1, 2006
68converted
772
Colorado
Mar 1, 2006
  • Mar 1, 2006
I promised I would post some picks of the console when I got it layed up. The initial pics I took were all blury so I don't have any prior to this point. I need to glass the underside and the cutouts for the drink holders and I should be able to smooth things out with bondo and get it painted. I also need to add a power top and fog light switches, then the gauges and I plan to add vents for the heater near the front. I grabbed a couple of vents at the pick and pull.
http://i48.photobucket.com/albums/f210/68converted/Console.jpg
And here is the start of the spare tire sub enclosure. I am using a 17" rim and tire for the spare. I layed plastic inside my Boyd's (scarry) and then the fleece. I soaked that with resin, dropped in the base board. layed in fiberglass (two layers). I was able to pull it out of the rim in a hour and will glass in the top half tonight.
http://i48.photobucket.com/albums/f210/68converted/insidesub.jpg
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Mar 1, 2006
  • Mar 1, 2006
Looks like a very cool project...keep the pics coming!
Daves1967
Chester, VA
Mar 2, 2006
  • Mar 2, 2006
Looks great! What did you use as a mold to lay the fiberglass for the console?
68converted
772
Colorado
Mar 2, 2006
  • Mar 2, 2006
Thanks guys, I was not able to do anything with the projects today but hope to glass in the sub box tonight. For the console- I used 1/2" particle board for the armrest and used used stucco screen to shape it. I used the fleece as a base for the fiberglass matt. Once the fiberglass was layed up I used cup wedges for the gauge placement and then glassed over them. I cut in some plastic tube stock for the cup holders I purchased from the marine shop and glassed over that.
I test fit the console tonight over the carpet and it is a perfect fit under the dash and will bolt up nicely. I have been searching the internet to find out how much sub box volume is needed for the sub I want to use. But, back to the poison of my life "American Idol" sad, very sad, but funny.
68converted
772
Colorado
Mar 3, 2006
  • Mar 3, 2006
I scraped the wheel sub enclosure. I am going to do this setup instead with a space saver spare. What do you guys think?
http://i48.photobucket.com/albums/f210/68converted/final2.jpg
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Mar 3, 2006
  • Mar 3, 2006
looks sweet that will do quite nicely. i'm sure your nieghbors will love to here you coming.
M
mtbdoc
245
  • Mar 3, 2006
Not a fan of square subs...just not a great design, despite what their marketing will tell you. Otherwise, your work is GREAT!!!
68converted
772
Colorado
Mar 4, 2006
  • Mar 4, 2006
I was able to sand down the console a little yesterday. Some progress but other things to work on before I get too far into it.
I am really not into the monster sound thing, (almost 40 now), but, from the research that I have done, the subs that work in the lowest frequency range will work best for the convertible. I don't want to rattle my newly put together car into pieces. So I will go with one 10" Alpine type X sub and call it good. I plan to mount the amps to the side of the sub, and not in the floor.
66moneypit
536
Northern Va
Mar 4, 2006
  • Mar 4, 2006
I have been struggling with stereo options since I bought my vert. The sub is what I go back and forth with. Cruising around town, isn't a problem but the wind noise at highway speeds is what I'd like to cut through.
David
68converted
772
Colorado
Mar 4, 2006
#10
  • Mar 4, 2006
  • #10
David
This very same issue is what I was doing research on. After reading a ton of technical articles, the low frequency subs are the way to go. Think of the drone of a muffer, it cuts through almost all noise. I am doing six speakers inside, two 5 1/2's in the kick panels, two 6's in the rear window quarter, and two small tweeters under the dash. We will see... I have also heard of putting speakers behind the rear seat, just to either side of the top pump. I tried 6x9's but they did not fit. I am going to try some 5x8 low profiles. I think it might work???
M
mtbdoc
245
#11
  • Mar 4, 2006
  • #11
HA! I am not going to have ANY trouble with my subs: going to run two 16Ov.2 from Elemental Design. They will be nestled within the rollbars [each seat has it's own rollbar] and about 12" behind the two seats! A very nice advantage to not having a back seat to worry about. Convertibles don't get any of the bass reinforcement usually seen in cars, so you need a LOT more cone and power to drive it. These will be run in parallel...and the eD 9.1 amp pushes >1200w into a 1 ohm load.
Probably going to go with front kick panel pods and see what kind of soundstage I can get out of it.
It's funny...I've been playing around with car stereos since the 70's...and this will be my first excursion into fiberglass. Got to do the console...and we still haven't figured out what to do with the dash. The stock dashpad and supporting hardware is gone, and the openings for the stock radio and defrost has been filled. Don't plan to drive the 'vert on a day I need defrost! In fact, I had planned to put A/C in, but am really rethinking that. Besides, if I'm going to stuff a turbo under the hood [instead of the KB blower] I need all of the space I can get!
68converted
772
Colorado
Mar 5, 2006
#12
  • Mar 5, 2006
  • #12
mtbdoc said:
... don't plan to drive the 'vert on a day I need defrost! In fact, I had planned to put A/C in, but am really rethinking that. Besides, if I'm going to stuff a turbo under the hood [instead of the KB blower] I need all of the space I can get!
I think with a bunch of sound deadener and the system I have decided to go with, it should work well. This is no trailer queen, and I want to drive the heck out. Fun factor is high.
66StangFastback
181
norman, oklahoma
Mar 5, 2006
#13
  • Mar 5, 2006
  • #13
I've got a cheap ass walmart system in my 66. I have 2 6"s in the kick panels, 2 6x9s behind the back seat, a 400 Watt amp powering the 6x9s and powering a 10" dual brand sub in the trunk. Sounds better than stock systems in modern cars. And I've spent less than 500 on the whole thing.
68converted
772
Colorado
Mar 5, 2006
#14
  • Mar 5, 2006
  • #14
Had a similar system in the F-250, but when I switched to the Alpine head unit and Type-R speakers, it was a major step up.
  • Locked
Expired 00/03 Cobra Clone Fully Built Street/track Monster Kenne Bell
  • BOSS GT
  • Aug 20, 2013
12K
SN95 Mustangs For Sale (1994-04) Oct 29, 2013
BOSS GT
Aftermarket AOD shifter in a console
  • 68converted
  • Feb 7, 2007
Classic Mustang Specific Tech Feb 8, 2007
68converted
T
Anybody Have a Custom Sub Enclosure Like This?
  • Todd00GT1
  • Apr 17, 2007
  • Mustang Sound & Shine All
Mustang Sound & Shine All Apr 17, 2007
Todd00GT1
T
Integrating AM Head Unit w/ Mach 460
  • mixedbreed02gt
  • Oct 19, 2007
5K
Mustang Sound & Shine All Nov 4, 2007
eliteJAE
Custom Audio in '03 GT Vert....PLEEZ HELP!!!!
  • soccerstang
  • Jun 7, 2005
1996 - 2004 SN95 Mustang -General/Talk- Jun 7, 2005
soccerstang
