MAF Conversion/Idling issues
  • Thread starter Thread starter JRPony
  • Start date Start date Apr 8, 2006
J
JRPony
83
Las Vegas, NV
Apr 8, 2006
  • Apr 8, 2006
A week ago, I did a MAF conversion on my stock motored 88. Got the PCM, harness and MAF out of an 89LX. I realize there is some adaptation time, but after a week it still runs worse then it did with my SD computer. When cold it barely idles (even stalling at times) and when warm it will idle a lot better, but just not at well as it did before. Under load, the motor performs fine.
I wondering if anybody had ideas on what the problem might be. Is the A9L fuel program more sensitive to temperature (possible problem with ACT/ECT/open loop fuel control)? My first thought would be the MAF I pulled out of the junkyard is not reading properly (I did clean it prior to installation).
I do not believe this to be a mechanical issue as no other work was done to the car other then the aforementioned items. The SD computer idled like a champ when cold and at operationg temp. All connectors are in place and the BAP/MAP vaccum line is plugged. Anybody have ideas?
D
Daggar
3,902
  • Apr 8, 2006
Disconnect the meter and verify that there's a change. Check TPS. Pull codes. Ensure that BOTH o2 sensors are functional (codes should help with this).
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 8, 2006
  • Apr 8, 2006
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
J
JRPony
83
Las Vegas, NV
Apr 9, 2006
  • Apr 9, 2006
Forgot to mention that there were no faults stored.
vristang
4,933
101
124
Seattle
Apr 9, 2006
  • Apr 9, 2006
I could be completely wrong here, so let me know if I am.
I thought the MAF cars used Barometric pressure not Manifold pressure (actually vac). Only SD uses manifold vac/psi.
If I am correct then disconnecting the BAP/MAP vac line should help your situation.
You could be showing the computer engine vac when it expects to see atmospheric pressure.
Again let me know if I am wrong, as I am just taking a guess here.
The only other thing I can think of is a repinning error, but that should have shown up as a trouble code?
jason
J
JRPony
83
Las Vegas, NV
Apr 9, 2006
  • Apr 9, 2006
jason
The BAP sensor functions the same as a MAP sensor. The only difference is the BAP is reading atmospheric pressure and the MAP reads manifold vaccum. So when doing a MAF conversion, the vacuum line leading to the MAP is disconnected from the sensor and plugged. This is what I did.
Also, I swapped the whole engine harness, thus there wasn't any pin relocation going on. But thanks for the input.
Anybody have any other ideas?
CRASH7772
401
NH
Apr 9, 2006
  • Apr 9, 2006
Do you have cruise? What about the VSS? I have done the same swap but I have a Pro-M and I did H/C/I at the same time. I had real issues with the SD when I did it but I didn't want to mess with it so I just converted with the 89 EEC and harness. I have idle issues now when cold but I think my intake needs to be retorked because once warm it idles fine. I hit 2-3 of them that I could get at and they were loose and now the problem has gotten better so I need to pull the upper and do them all in order. Did you change anything else. Once my demons are figured out I'm heading to the dyno shop for a SCT custom chip. I don't have cruise so that code and others that apply will be gone with the chip install.
D
Daggar
3,902
  • Apr 9, 2006
The vac port on the BAP should be left open, not plugged. It's how the EEC tells what atmoshperic pressure is at startup.
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
  • dan50
  • Jul 18, 2026
dan50
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
