MAF Conversion Specific......
  • Thread starter Thread starter Paul Perreca
  • Start date Start date Aug 29, 2005
Paul Perreca
1,085
  • Aug 29, 2005
In the breif about the conversion harness, it says, simply connect the one end of the harness to the Mass air sensor, and connect the other end to the "EXISTING" speed density wiring harness that connects to the A9L....
NOW!!!!!
What exactly does it connect to or plug into!!!!
, it says no cutting or splicing wires, so its gotta just be a plug, havnt seen the A9L comp yet, so does it just plug into that, along w/ the SD harness, or does the SD harness plug right into the A9L, and the conversion harness plugs into the SD harness, I'm all confused!!!!!! THANKS
Paul Perreca
J
jerryD
1,061
Gladstone, MO
Aug 29, 2005
  • Aug 29, 2005
on the corral someplace is a write up on this. basicaly the wires do "plug" in to the original harness. you just need to get some EEC-IV pins to do it. checkout www.fordfuelinjection.com for more
Paul Perreca
1,085
  • Aug 30, 2005
bump
Paul Perreca
1,085
  • Aug 30, 2005
wat the frig lol does anyone have a used MAF sensor (just the sensor, not the whole tube, i believe the sensor is black and comes off w/ a torx bit) That is the only peice I need)
BTW, someone said you can get the conversion harness off ebay for 40, and since then, I still haven't been able to find it!!!!! HELP ME FIND IT!!
Paul Perreca
J
jerryD
1,061
Gladstone, MO
Aug 30, 2005
  • Aug 30, 2005
go to the site posted above. they have it for $12, then you just by the terminals to connect to the computer.
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
F
3G Alternator install question
  • fathead429
  • Oct 24, 2026
1974 - 1978 Mustang II Talk & Tech Oct 25, 2026
LILCBRA
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
A
Electrical New O2 sensor harness has no jumpers (91/93)…
  • afjLX
  • Dec 11, 2024
Fox 5.0 Mustang Tech Dec 13, 2024
afjLX
A
