  • 1994 - 1995 Specific Tech
MAF location for turbo
  • Thread starter Thread starter rcmonster
  • Start date Start date Jan 31, 2007
R
rcmonster
14
Holiday, FL
Jan 31, 2007
  • Jan 31, 2007
I bought this MAF and injectors on EBAY. I was told by the seller that he had it between the filter and turbo. Pro-Flow calibrated for 30lb injectors. Pic attached.
On some pics have seen it between the throttlebody and the turbo. It would be easier for me to do it this way if it is interchangeable.
I am ready to install the turbo as soon as I delete smog and EGR. Also, if I want to just get a smaller belt to delete the smog what belt length do I need. I have a 95 GT with factory pulleys.
Thanks for your help.
OrangeMustangGt
1,976
Cape Cod, MA
Jan 31, 2007
  • Jan 31, 2007
assuming your doing a single you have to use it in front of the turbo, unless it is rated for blowthrough, then you can mount it after and use a vented to the atmosphere bov....i dont know how to tell if its a blowthrough, i had mine custom made by mass air systems
R
rcmonster
14
Holiday, FL
Jan 31, 2007
  • Jan 31, 2007
Green GT
Dude, I saw your mustang video on You Tube. I must have watched/listened to it 30 times. Imagining how it will be when I get it. I have all parts now and soon will do it. I am running a Super T-70 .70 & .70 single turbo.
Thanks Green GT. Badass Video also!
OinkAodeOink
3,026
Daytona bch, Florida
Feb 1, 2007
  • Feb 1, 2007
You know.. something to ask the tuner ( a real tuner, not some joke)
On all the systems I build I have been doing the 05+ MAF coupled with the Diablosport MAFIA, the 05+ MAF is MUCH more forgiving to bends, transition, before the meter, as aposed to previous MAF's.. This makes tuning much easier and makes drivability much better as well. I see the MAF flanges, and can source the MAF and MAFIA for you, if you find out that option will work on OBD1 cars. But for the OBD2 that is the way to go..
BTW, blow through is the only way to go on the MAF, if you want to do it right.
OrangeMustangGt
1,976
Cape Cod, MA
Feb 1, 2007
  • Feb 1, 2007
thanks for the complements.....i should really get a new video of front mount setup.
also, if your talking those super turbo's off ebay, i have heard that they are junk. people said that in a couple months the turbines are hitting the housing,,,,,,,figured i would warn ya. save up for a real master power man.
here is a pic of the one i used.....ite been workin great for about 2 years now
R
rcmonster
14
Holiday, FL
Feb 1, 2007
  • Feb 1, 2007
EBAY JUNK
I figured it was not gonna last for long. I just want to get everything going and setup correctly first, then I will worry about getting a good turbo. I do know a guy that has the same turbo I bought. He has had it in an eclipse for over a year now with no problems. He may just be lucky though. YES, MAKE MORE VIDS!! PLEAZE!
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
help me understand calibrated maf sensors and injectors
  • stackz
  • Sep 21, 2024
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 7, 2026
AeroCoupe
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
