MAF Mystery!!!
  • Thread starter Thread starter ACstang5.0
  • Start date Start date Jun 13, 2005
A
ACstang5.0
18
  • Jun 13, 2005
I noticed my car was bogging out at high RPMs and had no power, so i replaced my MAF with a replacement from autozone. It worked great for 4 days then my car just died in the middle of the road. I know its the MAF because when i unplug it it runs fine.
I was told to get a CL MAF (76mm), but im not too sure. my mods are in my sig so please let me know what you think. thanks!!!
also, the pictures of the CL MAF dont show the black chip on top, does it not come with everything?
stang22
1,318
Washington, D.C.
Jun 13, 2005
  • Jun 13, 2005
Have you hooked a computer up to it yet? The MAF housings don't go bad, but the MAF sensors do. If your sensor was bad, you would be pulling a code or your check engine light would come on when you disconnected it while it was running.
If you do get the C&L 76mm, make sure you get the sampling tube for whatever pound injectors you are running. Stock injectors are (yellow) 19lbs.
Tim
M
mikeflys1
217
CT
Jun 13, 2005
  • Jun 13, 2005
Vacuum leaks will do that too...My escort did that ran fine with the maf unplugged then died as soon as you plugged it in. Turned out one of the bigger vacuum lines had a split in it. Replaced it and ran like a champ.
HISSIN50
34
129
Jun 14, 2005
  • Jun 14, 2005
Going with the vac idea, a stockish motor should pull 15-20" hg at warm idle.
Good luck
A
ACstang5.0
18
  • Jun 14, 2005
will the C&L kit fit on my car? its 76mm and i think i have a 70mm TB
A
ACstang5.0
18
  • Jun 14, 2005
i didnt know the CL maf does not come with the electronics, where can i get just the electric sensor?
olymaster
179
columbus ga
Jun 14, 2005
  • Jun 14, 2005
never seen an escort that ran like a champ
Reactions: Keith5.0GT
BlackFox5.0
3,514
Massachusetts
Jun 14, 2005
  • Jun 14, 2005
C&L is junk. All they are is a housing that REUSES the stock MAF electronics, and "fools" it. If you are going to upgrade, go Pro-m (now Professional Mass Air Systems, www.massairsystems.com)
Try to find a used one if you can because the wait on meters from the "new" company is very unpredictable. I got mine a little over a month after I ordered it.
stang22
1,318
Washington, D.C.
Jun 14, 2005
  • Jun 14, 2005
BlackFox5.0 said:
C&L is junk.
I never had any problems with mine... If you are basing that off of personal experience, great. It seems to be about 50/50 with C&L, I guess I fell into the 50% that didn't have any problems. For blown applications, I wouldn't use C&L either.
Tim
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 14, 2005
#10
  • Jun 14, 2005
  • #10
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $33.
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
