MAF to cold air intake question
What type of problems are you having? There are four bolts/nuts (you can buy them from any hardware store if yours doesn't have them) You put the maf screen in the middle of them (if no maf screen the just silicone so fill the small gap left by it, works just fine).
If your having issues getting the silcone hose adapter over the tube or something try a litte lube.
Sorry if I was a bit too vague, the bolts for the 90 degree pipe does not line up with my MAF. my MAF(4") is bigger than the 90 degree (31/2 inch) I'll post pics of the actual pieces tomorrow but below is the CAI. I've searched every where for an adapter.
http://tunertools.com/prodimages/BBK/bbkcai_large.jpg
Is your maf not stock? 3 1/2 is about what the stock size is..... I'm guessing you have a 90mm maf?
Here is a pic of both
http://i1014.photobucket.com/albums/af270/99blkstang/DSC00730.jpg
Car was bought used and was told it was stock. Only had it for a month started restoring broken panels inside and finally getting around to the engine. I'm assuming no it is not the stock mass air since the CAI came off a 99 GT, I didn't get to see it on there or take it off so I don't know how it was installed.
