Maf vs Maf question
  • Thread starter Thread starter Acid7711
  • Start date Start date Sep 25, 2006
First Prev 2 of 2
1lostpony
#21
  • Sep 26, 2006
  • #21
yeah stock 99 electronics and every thing runs great,why wouldn't it work
the computer reads the same voltage on both meters the 99 is just bigger.
smokin91'
204
#22
  • Sep 26, 2006
  • #22
The transfer curves are way different on a 99 MAF compared to one for a Fox or 94/95.
I could unplug my MAF and the engine still runs. Doesnt mean its running optimally, as in the case of using a 99 meter.
If you are using a 94/95, go the machine shop route.
Skip finding the Flange adapter, youd have better luck finding The Chupacabra.
vristang
4,933
101
124
Seattle
Sep 26, 2006
#23
  • Sep 26, 2006
  • #23
Is this meter from a Mustang?
What is the part number of the Sensor?
Sorry to keep coming back with so many questions, but I would like to locate the actual MAF transfer for this meter.
Finding the MAF transfer for the A9L is easy enough.
The problem with mismatched meters is this...
The MAF meter converts airflow into a voltage. There is a specific relationship between the air flowing through the meter, and the voltage output of the MAS.
The voltage signal then travels to the EEC-IV.
Then, the EEC-IV will convert the voltage back into airflow units, using the same equation that was used at the MAF.
So there are 2 conversions...
Airflow to Voltage
Voltage to Airflow
If these 2 conversions are based on the same equations, then the cailbration of the system will be totally hosed.
There is no gaurantee that any 2 Ford MAF meters will convert from airflow to voltage using the same coversion factor.
Most likely the 99 MAF does not convert airflow to voltage using the same factor as the stock 55mm MAF did.
This means that the voltage signal to the computer could be skewed. The question now is how far off from the stock MAF is the 99 MAF.
Hope that helps make sense of this mess.
jason
1lostpony
#24
  • Sep 27, 2006
  • #24
they both read the same voltage i looked it up in the ford eec manual,from idle to wot same voltage reading across the board. the 99 mustangs use 19lb injectors just like a fox and 5 volts is still 5 volts,they use lightning meters and 42lb injectors on blown cars.
vristang
4,933
101
124
Seattle
Sep 27, 2006
#25
  • Sep 27, 2006
  • #25
The 0-5V range that you are looking at is the scale that the sensor reads on. It does not mean that the airflow that corresponds to 2.5v will be the same for both applications.
All of your sensors read on a 0-5v range, this is called vRef, or the reference voltage.
5v is used as the max because it is easier for the computer to control the output to the sensor at 5v, than it would be to control the output to the sensor at full 12v.
The fact that wot will still register as 5v, means nothing.
The question is what does 5v relate to, in terms of airflow.
The stock Ford EEC you have could call the 5v max 835kg/hr of air.
While the new sensor is actually registering 1000kg/hr of air, at the same 5v.
Just an example, I will have to look up the 99 Mustang MAF Transfer tonight when I have more time.
jason
vristang
4,933
101
124
Seattle
Sep 28, 2006
#26
  • Sep 28, 2006
  • #26
OK, I could not find the exact 99 MAF meter that you are running, as I am not sure what computer that meter is correct for.
But, I did find a 80mm MAF for a Lightning. I think the scaling will be pretty close though.
Basically, when 840 kg/hr is flowing through the 99 MAF, the MAF is putting out 4.1v.
But when the computer recieves the signal of 4.1v, it is interpretted by the A9L computer as being 600 kg/hr.
Not only does this mess with your AFR, but it also destroys the accurracy of the Load calculations done by the computer.
In this instance the lower airflows happen to be fairly close, so low Load driving should be ok. But you are going to be far from ideal at WOT.
WOT is not a running condition where you want to have a messed up AFR.
If you take this 99 MAF off, and install a correctly cal'd meter of similar size the car will run better AND SAFER.
(the other option is a custom dyno tune/chip)
Hope this helps clear up what I was trying to express.
jason
__MAF Output______Actual AirFlow________Actual AirFlow_______
____Voltage____________A9L_______________99 Mustang________
______.57______________13.6__________________9.4____________
______.75______________18.7_________________15.1____________
______.88______________23.6_________________20.1____________
_____1.09______________32.6_________________26.2____________
_____1.18______________36.7_________________35.1____________
_____1.32______________44.7_________________45.2____________
_____1.46______________54.2_________________57.3____________
_____1.57______________62.4_________________70.1____________
_____1.70______________72.9_________________87.3____________
_____1.80______________82.4________________105.8____________
_____1.89______________90.3________________------____________
_____1.99_____________100.1________________127.3____________
_____2.15_____________120.1________________151.4____________
_____2.31_____________142.3________________179.3____________
_____2.45_____________161.3________________210.3____________
_____2.58_____________182.5________________245.1____________
_____2.70_____________201.9________________283.8____________
_____2.91_____________243.4________________327.0____________
_____3.15_____________295.7________________390.0____________
_____3.35_____________347.3________________463.0____________
_____3.54_____________399.3________________544.0____________
_____3.88_____________499.8________________733.6____________
_____4.17_____________596.2________________843.4____________
_____4.44_____________695.7_______________1097.2____________
_____4.77_____________835.8_______________1244.0____________
____16.00_____________835.8_______________1552.1____________
First Prev 2 of 2
Fox Cobra wheels real vs. replicas
  • keel
  • Nov 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Today at 8:52 AM
AeroCoupe
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Rear Disc and Rims Offsets
  • TripleYellow
  • Nov 11, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 9, 2026
TripleYellow
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
