maff problems
aleborjas
610
hi i changed the maff case for a bigger one with the stock sensor i have the stock inyectors 19lbs and now it smokes and smell fuel in iddle, i had 30 pounds and 75mm maff and they were too big for my 306 with the stock intake and heads but now with the 19's i feel it slower should i put the stock maff case where do i have the problem? i tried to put a larger case because to get more air because the stock one is too smal,l i have the stock TB and 40pounds fuel press without vac.
lot of people told me to put back the 19's i always had the car with 30's never tried it with the stock ones, i have XE274HR cam too!
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
make sure your maf and injectors match, maf calibrated for 19's and 19's in the car, try running the smaller case, the car is only going to read the amount of air going throught the maf, a huge case isnt going to make difference. I would reset the comp. and let it relearn it.
hi can the problem be that i have 93 cobra computer but the maff is is the stock one the gt (non cobra), the cobra maff is the one calibrated for 24's? or the computer?
because i dont have the cobra maff i have the stock one with 19's inyectors
The Cobra MAF is a 19 lb MAF.
The Cobra computer is calibrated for a 19 lb MAF. The fuel tables inside the computer are what makes it possible to run the 24 lb injectiors.
aleborjas said:
what do i have to do to run 19's?
and i dont want to buy the 24' i plan to run 30's on future with the a new engine!
Get an A9L computer & a MAF calibrated for the injectors you want to run. Sell the Cobra computer to someone who wants a 24 lb setup.
Here's a book that will get you started with how the Ford electronic engine control or "computer" works.
Ford Fuel Injection & Electronic Engine Control 1988-1993 by Charles Probst :ISBN 0-8376-0301-3.
It's about $20 from Borders.com see http://www.amazon.com/ . Select boo...very good, and I found it to be very helpful.
