WRONG/BAD INFO, Cam and Crank bolts ARE TTY
better get a new/different shop manual because rod bolts can be used up to 3 times.
head bolts, cam/crank bolts and main bolts/studs are TTY, use them once and toss 'em
Just reading it to you straight out of Ford shop manual.
Remove the connecting rod cap, lower and upper connecting rod bearing. Keep cap and connecting rod bearings together. Use care to prevent damage to the bearing and cylinder bore surfaces.
CAUTION: Care should be taken not to damage the cracked rod and cap joint face surfaces. Engine damage may occur.
Connecting rod bolts (6214) are retained in the bolt hole with a light press fit. The connecting rod bolts have been torqued to yield at least twice and must be discarded. Use a hammer and punch to drive connecting rod bolts from connecting rod cap.
camshaft removal and installation:
Remove 14 bolts retaining camshaft bearing caps (6B280) to cylinder head
Tap upward on camshaft bearing caps at position shown and gradually lift camshaft bearing caps from cylinder head.
Remove camshaft straight upward to avoid bearing damage
Installation
Clean and inspect valve cover, engine front cover and cylinder head sealing surfaces.
NOTE: Steps 2 through 11 will install only one camshaft. If both camshafts are being serviced, repeat Steps 2 through 11 to install the other camshaft.
Position camshafts on cylinder head. Apply oil to journals and lobes of camshaft.
Install and seat camshaft bearing caps. Hand-start 14 bolts.
NOTE: Each camshaft bearing cap is tightened individually.
Tighten camshaft bearing cap retaining bolts in sequence to 8-12 Nm (71-106 lb-in).
No where in camshaft installation does it say to discard camshaft bolts.
I was under the same impression as you about them being tty.
