Main stud
  • Thread starter Thread starter RAYMOND259
  • Start date Start date Apr 7, 2007
R
RAYMOND259
56
  • Apr 7, 2007
Do you guys use locktite for main studs into the block?Will the studs come out of the block if i didnt use it?Thanks
blownLX5oh
42
  • Apr 8, 2007
While unlikely the bolts would actually 'come out of the block', it's cheap insurance to add a lil dab of loc-tight to the threads of each bolt....
Hope this helps!
Bobby
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Apr 8, 2007
  • Apr 8, 2007
From my understanding, you don't want to use anything other than oil or assembly lube on main studs. You have to torque them pretty good (80 ft lbs) and using something else may give you false readings.
T
TheUser
1,859
Springfield, MO
Apr 8, 2007
  • Apr 8, 2007
If I were using main studs (instead of bolts), I would probably put some locktite on the threads that go into the block. I wouldn't use the "permanent" type of locktite, probably just the light-duty one. The nuts on top of the studs, I'm really not sure. I used stock main bolts, and I don't think I put any locktite on them. I do remember I put locktite on my rod cap studs before putting the nut on.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
Engine Felpro 9333 pt1 (with 8psi boost)
  • JD1964
  • Jan 14, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
Qtrhrse23
A
79 mustang pace car spoiler.
  • Anglosaxon83
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 21, 2026
Anglosaxon83
A
For Sale Mexican 302 Block 60 Over , Comp Cams Roller Conversion and ARP Main Bolt/Head Studs
  • bluelx347
  • May 27, 2025
  • Engine and Power Adder
Engine and Power Adder May 27, 2025
bluelx347
