Maintenance Time - Urethane bushings?
ssbauer
58
Springboro, OH
It is time for some maintenance. I figure since I will have the front of the car jacked up. I will replace the steering rack bushings (the rack has alot of play) and sway bar bushings with MM Urethane.
Questions...
- Do you need to lubricate the steering rack bushings? I have heard yes and no.
- Should I do the sway bar endlinks? The car is 2002. Someone had said the 02's already had high quality endlinks.
Thanks ahead for your time.
!. Mostly every Urethane bushing needs to be greased before you install them, I would call up whoever you got them from and confirm when you should re-grease them.
2. You might as well buy new End Links because they are only $20, Order the MM ones. I had Energy Suspension ones and they wore out in 2 years.
