Major issues
90Fox Gt
Ok. hopefully somone will have some advice i just did a major performance upgrade i got a set of new trickflow twisted wedge heads and a tubular gt 40 intake. the problem I am having is i am sucking oil through my pcv system and is going out of my exhaust. i have replaced the intake and head gaskets again and I am out of ideas. so has anyone else ever had this problem before? and can anyone give me any advice i would greatly appreciate anything and am open to ideas. Thanks for anyones help. God im so frustrated!:mad:
Did you put the baffles on the lower intake near the PCV location? Are you running the screen under the PCV valve? Is the PCV good, does it rattle when you shake it? Do you have the vac tube coming from the valve cover to the TB? Is there oil present in the throttle body? Are you using stock or aftermarket valve covers, do you have baffles installed?
