Alright, so I honestly have no idea what is the deal with my cobra. I have a '94 5.0 s/c (powerdyne) msd btm full ignition system, upgraded MAS, injectors, and fuel pump (40#). New wires, plugs, dist cap, blaster coil, battery, fuel filter. Now this is the situation. I will start my car and it will kind of idle high, but i guess that is expected when it is cold outside, right? And then after a little bit it will calm down to the norm 750-800. But occasionally...when i start my car...it will idle really high to like 1700 and kind of surge up and down...but finally calming down to the norm idle. Then sometimes it will start just fine....but when I am headed down the road my car will try and die on me so I gas it and it is like there is no spark....followed by a quick increase of power...so i take my foot off of the pedal. And it will just surge up and down the RPM range up to 2K (w/o my foot on the gas). I am not too sure what the ordeal is. I have taken the car to Ford and had a "recorder" hooked up to my ECU...and recorded the incident when it happened (maybe a hand full of times a week). And Ford is just clueless...but their recorder only gives outputs such as fuel trims and air ratios. Curious if there is anyone out there that has had some similar trouble when a 94-95 5.0 is S/C'd. I have been living with this situation for a while since I am in the Navy and need that car as a daily driver. It is just annoying as crap to not know what the source is. Does anyone think that it is the chip? Any help would be greatly appreciated.
~Justin~
~Justin~
