i have alot of sensors unhooked cause i was told they are not neccessary for the vehicle to run, the H.E.G.O sensor is unhooked, and the EGR ( its plugged off), the A/C plug., the barometric pressure sensor, the oxygen sensors, theres a couple more but i cant quite remember, also, just a few minutes ago i took off the valve cover, made sure both valves were closed, made sure it was at TDC, the rotor is one number one plug, i am running the 137..... firing order, the same order as the ECU, the ECU is good, its reading almost nothing through the signal return, the TPS is reading a steady .98, the injecters are getting 13.64V with just the key on and not running, when i turn it over it reads almost a steady 10.67V. i am at a loss, i am half tempted to burn the damn thing!!!@!!!!!!!!!, i am going now to get some contact cleaner to clean the ten pin connectors for the injector harness..... one more thing, would the iac sensor cause it to not start when perfectly in time?? i wouldnt think so but im not really speaking from too much experience, i know that the motor has the 137... firinhg order, and i know that for the 90 gt they only put one motor in it, that motor was the 5.0 H.O and the firing order was 137... EVERYTHING is good!! what the hell is going on!!! the only thing that i can conclude is that the injectors are not pulsing, what would make it do that?? the ECU is good, i just removed it and completely inspected it, no burnt leads at all, and the signal return test is good, ****IN ****!!!!!
