  • SN95 V6 Mustang Tech
Makin oil?
  • Thread starter Thread starter barj1023
  • Start date Start date Jun 5, 2010
barj1023
  • Jun 5, 2010
i have a 2000 v6 auto mustang and it seems to be magic and able to create oil the only problem is a week ago it was using oil (bout a qt every 200mi) which seemed to be due to a bad pcv valve and sucking it thru the valve cover which i have read is a common problem but now the hose to the intake is clear! but now it seems to be able to "create" oil (im not sure what fluid is being added to it) its not using any coolant or any other fluid so the only thing is someway from fuel to get from the injectors to the oil? motor runs fine so im kind of at a loss of whats going on so any ideas or suggestions would be apprciated thanks!
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jun 6, 2010
  • Jun 6, 2010
Perform a compression test. Post the results.
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
SBF rebuild with no oil pressure NEED HELP
  • Falcon67
  • May 27, 2025
1965 - 1973 Classic Mustangs -General/Talk- May 27, 2025
horse sence
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
SN95 V6 Mustang Tech Jul 14, 2026
joeybuddy96
J
