Manual linkage block mounted pivot ball
iskwezm
4,159
20
79
Rowland Heights,California
Im getting to drop im my new engine and im swapping over all the small stuff while its on the hoist.I have a 5 speed and im using the 4 speed manual linkage,the new block is a newer late model that doesnt have the threded insert for the pivot ball.Has anyone ever heard or seen this "adaptor" i was told i could find????Im at a standstill on this install :bang:
Yup, I just did the same thing and I found the bracket at Sacramento Mustang in sacramento. He is right, it bolts to the bell housing and works perferctly!!
Alex
P.S. What flywheel did you use? I ended up with a 50oz 157 from ford racing and I had a problem with my old clutch pressure plate. It had a differnet bolt pattern than the newer flywheel. Now I am trying to get the linkage to move far enough back to work.Let me know if you have the same problem and how you fixed it.
