  • SN95 4.6L Mustang Tech
manual swap
  • Thread starter Thread starter ktaylOR2012
  • Start date Start date Mar 4, 2011
ktaylOR2012
256
stl.Mo
Mar 4, 2011
  • Mar 4, 2011
so im going to start buying parts to make my 2002 mustang gt auto a 5speed manual. i just need to know what i need and were is the best place to get it i know i need:
shifter
manual pedal set
clutch cable
quadrant
firewall adjuster
manual shifter bezel
shifter base insulator
shifter handle
engine separator plate
pilot bearing
clutch kit
flywheel
flywheel bolts
pressure plate bolts
trans
trans fluid
trans sensors
shift fork
x-member if going t56
manual trans wiring harness
driveshaft
is there anything else i will need and if anyone finds a good deal on any of that plz post the links
txredgt
1,343
33
69
Mar 4, 2011
  • Mar 4, 2011
shifter
manual pedal set
clutch cable
quadrant
firewall adjuster
shifter handle
pilot bearing
clutch kit
flywheel
flywheel bolts
trans
trans fluid
trans sensors
shift fork
driveshaft
I don't want to discourage you but this won't be cheap, at all. I know you just got your car but maybe should have looked a bit more for a 5spd rather than swap it all out? I don't have that much experience with something on this level but it just seems excessive. Do you plan on doing the swap yourself? I don't see a transmission listed.. Do you already have that lined up and waiting to go?
I see it hidden now.
3,287
24
69
Broke
Mar 5, 2011
  • Mar 5, 2011
I am going to be doing this very soon. Its been done before, and it is not cheap. Expect to spend at least $1500. My swap is going to cost more like $2500k, although I'll sell the auto kit once I'm done.
I'm buying nice parts as I do the swap. The finished product will be an upgrade over the stock trans setup.
I'm also collecting parts, so we should be able to help each other out...
I got a great deal on a Ford Factory Reman T3650 that has all the TSBs completed (including the expensive one - read the huge 3650 issues thread). It was 950 shipped and looks like new. They have three left but have raised the price 50 bucks.
http://cgi.ebay.com/ebaymotors/2001...arQ5fTruckQ5fPartsQ5fAccessories#ht_813wt_805
3,287
24
69
Broke
Mar 5, 2011
  • Mar 5, 2011
You have a windsor or romeo?
Heres where I am at relative to your list. I added a couple little things and asked a few questions...
PM AMstanger to get your American Muscle dicount code if you end up buying a load of stuff from them like I did. They are a great company.
shifter - Bought MGW. Also their inner dust boot. $197 shipped.
manual pedal set - Bought a nice 03/04 Cobra pedal box on ebay for ~$150
clutch cable, quadrant, adjuster - Bought cable, quadrant and adjuster for $100 American Muscle
manual shifter bezel - Dont think this is a must. one guy re-used the auto one. Either way its a cheap part.
Leather shift boot - Bought from American Muscle. $50
shifter base insulator - Lower Shift Boot / PLate was about $50 new. ebay.
shifter handle - Ford Racing shift knob from American Muscle. $40 ish
shifter gasket if you dont want to use silicone. $10 at American Muscle
engine separator plate - Whats this???
pilot bearing - Bought Ford. American muscle. $10
clutch kit - Bought RAM HDX from American Muscle. $250
flywheel - Bought Spec Aluminum flywheel. 6 bolt. Open box $250. Looks like a nice piece. Replaceable friction disc.
flywheel bolts - Came with flywheel
pressure plate bolts - I think these came with the flywheel. Has a big bag of hardware.
trans - T3650 Ford factory re-manufactured (all TSBs done) $950 shipped.
trans fluid - Need to re-read that T3650 thread and buy the right fluid. Rave reviews for royal purple...
http://www.americanmuscle.com/royal-purple-synchromax-manual-transmission-fluid.html
trans sensors - ?????
shift fork - Ford OEM shift fork kit. $50 bucks new.
x-member if going t56 - Does the stock crossmember work with 4R70w and 3650 then? I dont need to change mine? I think the crossmember for 99+ 4r70w and T3650 are the same. Need to confirm at the Ford parts counter.
manual trans wiring harness - This is where I have to most questions.... whats different about the harnesses? Do we have to replace (~$160) or can the auto harness be modified slightly? Also how is the stock ECU going to react. The other guy that did this swapped his ECU too.
driveshaft - Bought Ford Racing aluminum DS from American Muscle for $300
or can just get a 5spd yoke for your stocker for about 75 bucks. Steeda.
ktaylOR2012
256
stl.Mo
Mar 5, 2011
  • Mar 5, 2011
no idea lol that just what i was told and iv been looking and cant find anywhere
ktaylOR2012
256
stl.Mo
Mar 5, 2011
  • Mar 5, 2011
did you buy one from here i hate buying **** of ebay but if someone does first and its not a scam.
3,287
24
69
Broke
Mar 5, 2011
  • Mar 5, 2011
Yup. Great experience. Theyve sold a bunch. These are the last of them. Snap it up!!!!! It has ALL the TSBs completed which is crucial when buying a 3650.
Leah is very helpful arranging shipping etc. Ships in a wicked nice crate. Looks brand new.
ktaylOR2012
256
stl.Mo
Mar 5, 2011
  • Mar 5, 2011
soo ya this job for me is put on hold for all the parrts for me it would be just about 2900 and i was going to have some1 do all the work for 800. thats just a bit to much atm imma buy my rims and tuner then by this dec im going to have a shop do everything for 3500
txredgt
1,343
33
69
Mar 5, 2011
  • Mar 5, 2011
If you are REALLY wanting a manual, the best thing to do is sell your car now before you get too far into it and find one. You might end up paying a little more for it than you got your last car, but it will have everything done and ready to go for less than the 3500 to swap it all out.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
E
4.6l auto to 5.4l 6 speed
  • EastanF5
  • Jan 22, 2026
SN95 4.6L Mustang Tech Jan 22, 2026
EastanF5
E
C
5r55s auto to TR3650 Manual swap 4.0 V6
  • Ceskz
  • Feb 24, 2025
  • 2005 - 2014 Specific V6 Tech
2K
2005 - 2014 Specific V6 Tech Mar 27, 2025
89ripper
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
