Map sensor
  • Thread starter Thread starter somebody
  • Start date Start date Aug 7, 2005
somebody
22
  • Aug 7, 2005
I have done a search but i havent found any threads with the same problem i have. I bought a mustang with a cracked block and i put a new motor in it. When i did this i had a little problem with the vacuum lines. Today i pulled the intake and found that pcv valve was missing. I thought this was going to be the problem to all of my missing and popping. So after installing a new pvc valve i drove it around and still found a litlle miss. When i opened the hood i looked at the map sensor and saw that it had a electrical connection but it did not have a vacuum line on it. So what my question is where does that vacuum line run from on the map sensor? Thanks for any replys.
Brandon
stang22
1,318
Washington, D.C.
Aug 8, 2005
  • Aug 8, 2005
There shouldn't me any vacuum going to the MAP/BAP sensor.
Tim
HISSIN50
34
129
Aug 8, 2005
  • Aug 8, 2005
Are you correctly referring to the sensor? A MAP sensor does have a vac line attached to it. MAP sensors are used in SD set-ups.
A BAP sensor, used on MAF cars, does not have a line attached to it. It simply monitors ambient atmospheric pressure.
I dont think I saw a year for your car, so chances are that Tim is correct. But since you did mention MAP, it caught my eye.
Good luck.
stang22
1,318
Washington, D.C.
Aug 8, 2005
  • Aug 8, 2005
That's right... If it is SD, then it will have one. If he converted to MASS air, he won't. Good catch JT!
Tim
http://www.stangnet.com/tech/maf/massairconversion.html
somebody
22
  • Aug 8, 2005
Thanks for the replys i have a 89 so i wont have a line going to the map sensor. Man i guess i will have to find out where this leak is coming from. Thanks anyways.
Brandon
HISSIN50
34
129
Aug 8, 2005
  • Aug 8, 2005
cool. FWIW, a stockish motor should pull 15-20" hg at idle.
Good luck.
M
Map sensor
  • miser143
  • Aug 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
AeroCoupe
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
D
Please help with vacuum lines
  • Dawgs000082
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2026
Dawgs000082
D
Resolved 83 alternator wiring harness
  • sparten5000
  • Aug 2, 2026
Fox 5.0 Mustang Tech Aug 23, 2026
limp
