Alright, so I'm reluctantly joining the ranks of the minions who have posted in tech about this topic. I've read through about 20 threads on this and still don't feel entirely confident/haven't found the info I'm looking for. I'm hoping HISSIN50 will chime in
. I have the FK-35 DCC kit.
What's throwing me off is that the Mark VIII fan has three wires, two black and one blue. Obviously the fan has high and low speeds, but the wiring diagrams in the instructions make no mention of which wires go where. They only say fan (+), fan (-), battery (+), battery (-). Is the blue negative and the two black high/low? Do both high/low speeds go to the (+) terminal of the controller and the (-) to the (-) terminal?
Also, my car has a stock 195* thermostat in it, and the directions say the DCC is programmed for 180* tstat. Will I have to jump out pins to get it to work properly?
Which wire do I tap into from the A/C harness to make the fan work properly with my air conditioning?
What does the LED light included in the kit indicate, and do I just match the colors of the wires of the LED to the same color wires in the kit?
So many questions! Please help! My spare time is pretty limited and I'd like to make this install as productive as possible by learning all I can before I dive in. Thanks!!
Chris
. I have the FK-35 DCC kit.What's throwing me off is that the Mark VIII fan has three wires, two black and one blue. Obviously the fan has high and low speeds, but the wiring diagrams in the instructions make no mention of which wires go where. They only say fan (+), fan (-), battery (+), battery (-). Is the blue negative and the two black high/low? Do both high/low speeds go to the (+) terminal of the controller and the (-) to the (-) terminal?
Chris
