Mark VIII Temp relay
LaserSVT
3,548
233
If I get a Mark VIII fan on ebay or something do I have to buy a thermostate for it or does it have that and the a/c relay built in?
The MK VIII fan normally does not have a built in controller. That is an extra item ranging in cost from $30-$120. If you don't have a high current alternator, you can forget about using the fan. The stock 65 amp alternator isn't big enough to run the fan and the rest of the car.
The best fan controller available today is a DC Control unit. www.dccontrol.com. Cost is about $110. Be prepared to wait 4 weeks or more to receive your controller once you have sent in your payment. The controllers are custom made in small lots and lead times can stretch out.
Next best is a SPAL controller - $70-$90 See http://www.spalusa.com/fans/automated/accessories/fanpwm.html. Ebay will have the controllers for the $70: do a google search and see what you find.
At the bottom are the Hayden or Imperial controllers available through Advance Discount Auto Parts and AutoZone. The non adjustable one is about $30 ( Hayden 226206) and the adjustable one is about $60 (Hayden 226204). I recommend you do a google search on Hayden and the part number for more info.
If you are good with electrical stuff (90% of the people here aren't), build your own controller.
attachment.php
If you are an experienced electonics tech or electrical engineer, email me and it will send you the prototype drawings of a fan controller that is probably as good as the DC Control unit. It is a build it, troubleshoot it yourself item. I will not build or troubleshoot units, so it is not suitable for anyone who isn't really good with electronics.
Thanks jrichker:lol: Your knowledge is always helpful. I do have a 3g that I am going to put on the 2g pully today because at idle (750rpm) with the a/c and lights on only supplies 12.2 volts b/c of underdrives but at 1-k-rpm is at 14.1. But I am good with electronics, I am M.E.C.P. and a computer tech, so electrical is duck soup for me. I will try and make my own, I have the relay's and wires, now I just have to find a thermostat switch.:shrug:
JRichker's diagram is for a simplistic relay energized system. I think when he mentions building your own, he is thinking of something that works with PWM.
Jrichker, though I'm not sure it would be able to handle it in this situation (ergo you omitted it on purpose) but quite a few folks have been saying that the Soft start FAL controller works well for them. It might be worth inserting a one-liner into your informative post since it seems to be a viable option.
From the diagram, High temp limit switch: http://www.pressureparts.com/Pressure-Part-411266.aspx
A place to mount the temp switch:
Alternate placement for a temp gauge sender: Use the heater feed that comes off the intake manifold. Cut the rubber hose that connects the manifold water feed to the heater and splice in a tee adapter for the temp gauge sender. Be sure to use the same water feed line as the ECT sensor. That way you will get the most accurate temp readings.
Tee adapter info:
Make a pilgrimage to your local hardware or home supply center and get some copper pipe and a tee that fits the temp gauge sender. Solder two pieces of copper pipe onto a copper pipe tee with threads in the tee part. Find the correct brass fitting to match the temp sender threads to the tee fitting.
attachment.php
