MAS qusetion?
  • Thread starter Thread starter everynameistake
  • Start date Start date Jun 16, 2005
E
everynameistake
36
  • Jun 16, 2005
can you get a aftermarket MAS re calibrated to a different injector???
bullitstang1313
713
Indianapolis / Columbus, Indiana
Jun 16, 2005
  • Jun 16, 2005
I think you mean MAF as in the Mass Air Flow meter. Yes, you can get a MAF calibrated to different injectors. The stock maf was calibrated for 19lb and the cobra's had 24lb.
D
Daggar
3,902
  • Jun 16, 2005
The Cobra meter was not calibrated for 24s. The computer was programmed to deal with 24lb injectors.
But yes... you can have a meter recalibrated. There's a link in my signature for an outfit that can do it.
SlowGT
826
Columbia Co, PA
Jun 16, 2005
  • Jun 16, 2005
You were correct with MAS. However, it's more commonly known these days as the MAF meter. As a matter of fact, I think it's always been a MAF meter on 5.0 mustangs. GM used to call them Mass Air Sensors. Maybe they still do, I don't know . Both of them fuction the same...incoming air passes over a hot wire. Guess it just depends on what circles you run in as to the terminology.
In answer to your question: some meters require electronic recalibration (i.e. Pro-M) and some can be setup for other sizes of injectors by changing the sample tube (i.e. C&L)
super302
I'd do anything for free Bapples
May 29, 2004
2,878
Davenport, IA
Jun 16, 2005
  • Jun 16, 2005
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Engine Contour fan CFM
  • Mustang5L5
  • Apr 6, 2026
Fox 5.0 Mustang Tech May 22, 2026
qikgts
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Pro-M 75MM Bullet Flow Sheet - Is this calibrated for 36 # injectors?
  • dan50
  • Jan 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jan 11, 2026
dan50
Engine Valvetrain Calibration
  • PonyGTrider
  • Jun 12, 2025
Fox 5.0 Mustang Tech Jul 13, 2025
PonyGTrider
