Ok I'll start from the top. I searched this out but I couldn't find my answer...
I followed all the wiring steps as described by the tech article here at Stangnet by Mike Stowe to try to convert my 86 GT 5.0 to mass air. I have an innovative technologies 4 wire adaptor harness for the maf. I will be using a A9S cpu and a Pro-M 76mm bullet maf.
I ran the 4 wire harness through the firewall to the cpu connector. I wired in the red, black, brown and blue, as instructed, no problem - excellent install.
PROBLEM #1
I then went to do the pump thermactor pump pin moves as outlined in step 4. I moved pin 51 to pin 38 on the connector as described even though my wire colors were different than in the article. I then went to move pin 11 to pin 32 but low and behold! ---There is already a wire going into 32 and the wire I was moving from 11 is pink and blue. Not thinking much of color I still don't know why that spot is occupied?? And yes I have the connector right side up....
Do I need to do these thermactor pin swaps, I don't have any smog on the car whartsoever.....?????
Then I went to complete the next two "optional steps" to prevent any problems later on. First I completed step #5 the fuel pump monitor signal without problem.
PROBLEM #2
I then went to vehicle speed sensor wiring. My car does not have cruise and I was worried I would have the stalling out issue. I found the 8 wire harness behind the driver's kick plate. however I could not find the orange/yellow wire nor the dark green/white wire. The instructions I have that came with the adaptor state that if pin 3 + 6 already have terminals inserted in them then skip this step. Well in my connector pin 3 is empty but pin 6 is full.....So do I really need to do this step as well?
I then completed step 8 in regards to the map senssor.
I really need your guys help because as soon as I finish the wiring I can start building my engine.
PROBLEM #1
PROBLEM #2
