Mass air conversion now rough idle
  • Thread starter Thread starter FiveOfastback
  • Start date Start date Oct 1, 2005
F
FiveOfastback
32
Bethlehem, pa
Oct 1, 2005
  • Oct 1, 2005
Did a mass air conversion on 88 put in A9L computer C&L 76mm mass air and still has stock throttle body. We do have a 24lb sampling tube for a 73mm, could this be problem? I unplugged maf sensor and it will idle for a few minutes then stalls. Could it be a maf sensor? I didn't do the optional wires on the instruction it is a used maf sensor. What can I clean it with? Any suggestions?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 1, 2005
  • Oct 1, 2005
The sampling tube must match the injectors or you will have problems.
Optional wires? please explan.
See the Sticky "Help me create the Surging Idle Checklist" at the top of the forum for help with cleaning the MAF and how to check it for proper operation.
F
FiveOfastback
32
Bethlehem, pa
Oct 2, 2005
  • Oct 2, 2005
Put a new maf and MAS Air from advance and all is well. Still has a stall once in a while but no more rich condition.
N
noslow86
68
sandwich il
Oct 2, 2005
  • Oct 2, 2005
reply
did you run the red wire from the computer to under the drivers seats where the fuel rely is that clear up my idle. but they say it will have a little bit of a rough idle when you change over to mass air. are you runing the stock air box to the mass air or do you just have then filter off the mass air mine run like **** with just the filter at the end of mass air then i put the stock air box on it ran fine
J
jerryD
1,061
Gladstone, MO
Oct 2, 2005
  • Oct 2, 2005
the 73mm and 76mm use different sampling tubes. go to c&L's web site and you can see that on the chart.
F
FiveOfastback
32
Bethlehem, pa
Oct 2, 2005
  • Oct 2, 2005
The place I ordered the tube from for the c&L sent wrong tube, they sent me a 24lb for a 73mm instead of a 76mm.
I bought a stock maf and mas from Advance for a 92 GT (19lb) setup. It seems to be cured. with the stock motor. I have a GT40X motor sitting on the stand waiting for some parts to go along with it. ie: new x pipe and catback exhaust. The X motor is going to get a port matched typhoon upper and lower and 24 lb injectors
Paul Perreca
1,085
  • Oct 2, 2005
what optional wires
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
  • dan50
  • Jul 18, 2026
dan50
