Mass air flow question
jchav02
116
29
49
I've been having a hard start problem with my car it usually takes 5 or 6 tries before it finally starts also the car hesitates at wot and backfires. I did a fuel pressure with KOEO 0 pressure KOER 30 pounds turn the key off immediately drops to 0. I pulled the vacuum from the fuel pressure regulator no smell of gas. Before changing the fuel pump I pulled the mass air to clean it and found that one of the wires is bent. Does that wire being bent affect anything?
I doubt it, as long as it is only bent, not broken.
Does your car throw any codes? You should be having fuel pressure KOEO. The fuel pump should kick on as soon as you turn the key to the ON position.
Dump the codes: Codes may be present even if the Check Engine Light (CEL) isn't on.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Yeah the fuel pump turns on makes the same noise as it always did just no pressure. I havent pulled the codes gonna do that tonight the car idles perfect just hard starting and hesitation at wot.
I ran the codes I got 31 and 96. So I followed jrichker's guide tested the dark green/yellow wire on the fuel pump relay no voltage. Went to back to test the inertia switch not sure how to do this I pulled the connection and tested the two wires green/yellow has 7 volts and the brown/purple one has 0. Then went back to the front and and tested the pink/ black and got 12 volts. Did I test the inertia switch properly?
