mass air vs. speed density
1fastsn95
122
Carthage, tn
Ok, I got this bone stock 87 LX Im wanting to put a cam in. Not so much for power, but for the sound! Nothing sounds better than a cammed 5.0! Anyway, can anyone tell me "why" i have to convert to M/A to do this. What would happen if I didnt convert to M/A?? Also, what is the cheapest, most economical way of converting to M/A?? Thanks guys!! Chris
Because Speed Density takes vacuum readings to determine how much fuel to inject. The cam messes with the vacuum and the computer basically can't figure out how to run the car.
Cheapest way to convert
Ebay
stock MAF
Stock rubber intake tubes (there are 2)
A9L (5-spd) or A9P (AOD)computer
IST Mass Air Conversion Harness
http://www.mass-air.com/Products.htm
Of course you could go for a larger aftermarket MAF or a CAI of some sort, but that should get you started. If you don't have factory CC, you'll need a VSS setup as well
Lang said:
you can change cams AND stay speed density...i'm sticking with sd cuz it's cheaper, simpler for my simple mind, and is quicker on a less heavily modded car cuz no maf restriction an more aggressive computer...here's a link on SP cam options; http://www.50tech.com/viewtopic.php?t=50694
rock on
This may be true on a stock engine but not on anything the least bit modified. I doubt my 80mm pro-m presents any kind of restriction considering that after converting to mass air my car's throttle responce is better and it feels a bit more powerful. If the SD computer is more agressive it is only by a very small margin and most likely unnoticable. Mass air has much greater accuracy in metering air intake and thus is much more accurate in providing the correct amount of fuel to the engine.
CAI = cold air intake, VSS = vehicle speed sensor. From what I've read you need a VSS with manual transmissions so the engine wont die on decell.
Duh! on my part! I shoulda known what CAI was haha. But Ive never even heard of VSS! Looks like I need to make the swap though. Will the A9P comp swap right in? Is this a factory computer from a M/A car? Thanks again! Chris
Yes, the A9L is from a manual trans mass air '88-93 5.0 HO. The A9P is from an automatic. Doesn't seem to matter which you get.
I don't know that I would call it more accurate, but perhaps more flexible. The temperature compensation is better and it can accommodate changes in airflow better. On the other hand, SD is more involved tuning-wise, but IMO equally capable. Now that I know how much less difficult chipping an EEC-IV is that I first thought, I wouldn't be afraid of going with a radical SD EEC setup.
I am doing a conversion on my car right now
The mass air is going to help you a lot on performance over the speed density. I have the same car you have. red, 87' lx no cruise and speed density and I am converting my car right now too. I bought my conversion kit from a guy on ebay and got it cheaper. you can buy the conversion kits from summit and pay like 540 for the kit. I got my kit for 300. you are going to have a red, black, brown, and blue wires. you have to run them to the new computer. Also, we dont have cruise control so we have to get the speed sensor, electrical connector, and a speedometer cable. your computer will not work w/o these 3 things. you will also need to splice 3 additional wires in pin 19, 3, and 6 on the computer. they run to the fuel pump and speed sensor. you can buy the speed sensor, electrical connector, and speedometer cable as a separate package from ford or interactive systems & technologies. (706)-692-2018. I hope this helps you on your conversion
My car didn't have cruise or VSS... when I converted I didn't mess with the VSS and it ran/idled just fine. I did hook up the fuel pump monitor wire, and switch around the 2 wires in the main harness plug in though. I used the piggyback harness from Pro-M/IST. It worked like a champ. I also used an AOD EEC (can't remember my calibration code though). No problems with the car at all.
Having said that, if I had it to do all over again, I would have just chipped the Speed Density. The only problem with that, is that anytime you do a major mod you must re-chip it. Mass-Air grows with your combo much better. But with all the pros/cons, I wish I would have stayed with Speed Density and got it dyno tuned.
i need help too. MAP sensor
I need help too please, i have a 86 GT that has been MAF converted. and the car has been down for a year, and i just got the engine back in it and running..sound great, but i have not drove it yet, still doing odd's and ends to it. here is the question i see what looks like a MAP sensor, and it looks like it is hooked up, but there is no vacuum line going to it. I dont remember if i took this off or not ? the car starts good. but i dont know if it was taken off for the MAF convertion ? or if i did it. should i hook this up to a vacuum line or not ? anyone know if there's is hooked up ?
thanks
chad
:SNSign:
