  • 1994 - 1995 Specific Tech
mass air??
  • Thread starter Thread starter homie3186
  • Start date Start date Mar 27, 2007
H
homie3186
  • Mar 27, 2007
will a pro-m mass air that was on a 97gt fit my 95gt
mustanggt94
642
Indianapolis, IN
Mar 27, 2007
  • Mar 27, 2007
I believe it would work but you would have to have it recalibrated for the 95. The sensor should be the same with the same connector. Last time I checked with Pro-M (they are now Professional Mass Air Systems) they charge $99 to recal and do a flow test on one of their meters. So if you are getting the meter for a deal then it may be worth it.
I'd check with Pro-M first to make sure though.
http://www.massairsystems.com/
blksn955.o
3,263
st.louis mo 314
Mar 27, 2007
  • Mar 27, 2007
I am fairly sure the 96+ had a new style connector at the maf plug pigtail. I run a 98gt maf and had to get the new style pigtail. That and the flange at the front of the meter that bolts to the air filter (if aftermarket filter is used) is bigger than the 94-95 needing a bigger or modded part there.
hollywoodstang
1,095
Mar 28, 2007
  • Mar 28, 2007
Don't do it. Buy a new one that is for your car. They have good deals on many different sites. buy new one no headache, and no questions.
hollywoodstang
1,095
Mar 28, 2007
  • Mar 28, 2007
If you live in hot area C&L is better. but pro-m is better on cooler weather. Just a thought
blksn955.o
3,263
st.louis mo 314
Mar 29, 2007
  • Mar 29, 2007
On a load based 94-95 eec the C&L is the last meter I would run. At least the fool method with the Pro-M/PMAS has a maftransfer of somekind along with better ease of tuning.
badstang123
397
Santa Clarita, CA
Mar 30, 2007
  • Mar 30, 2007
+1 I had all kinds of trouble running a C&L in hot weather. Never again.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Mar 30, 2007
  • Mar 30, 2007
To answer your original Q ..........
There is the mechanical fit of a meter
and
There is the electrical fit of a meter
Unless you have access to the maf transfer curve with pcm access
or possibly one of those maf adjuster interface box doo dads you
are kinda taking a chance with trying other meters.
btw ... I did some long exhaustive heavy reading
the other night on Granatelli Meters.
I had seen Don say they were made very accurate
and
After my research ... I was very impressed
Grady
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
F
Pro-M is alive.
  • fasterthangas
  • Jun 22, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jun 23, 2026
AeroCoupe
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
