Master Cylinder Upgrade?
  • Thread starter Thread starter GTwannabe
  • Start date Start date Sep 2, 2004
GTwannabe
1,073
Red Hook, NY
Sep 2, 2004
  • Sep 2, 2004
I have a 66 Coupe with the straight 6 and manual drum brakes all around. Would like to upgrade the single master cylinder to a dual for safety reasons. Adding a vacuum booster to the car would be nice too.
I plan on installing a built 302 eventually... will the V8 fit with a power dual master cylinder?
bull999999
112
  • Sep 2, 2004
The SSBC front disc brake kit I got for the 65 came with a 67 Mustang dual master cylinder so maybe it'll work for you. As for the vacuum booster, it won't clear with the mentioned MC because the shock towers will get in the way.
D
DJs350H
91
Los Angeles, CA
Sep 3, 2004
  • Sep 3, 2004
Yes, you can get a power booster in a 65 with a dual master cylinder. A few companines now make that a conversion... I bought a Trans Am Racing system and it is top notch, although I haven't road tested it yet. I'm also aware of two kits offered through National Parts Depot, with a model that will cover all the possible applications. e.g. disc/drum, disc/disc, manual or automatic transmission etc... I believe one kit requires you to fab lines, and the other is supposed to be ready to drop in. I believe the one that requires fabbing of lines has a smaller booster, but I'm sure they can help you more from here.
DJ
68 manual disc/drum master cylinder
  • Butchd88
  • May 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- May 27, 2026
Butchd88
O
1967 Manual Drum Brakes , replaced the master cylinder and the brake light switch but the brakes lights stay on.
  • OldNSloww
  • Jul 14, 2025
Classic Mustang Specific Tech Jul 16, 2025
horse sence
W
New here, 1967 getting an efi 348 stroker.
  • Weeman348
  • Mar 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
Weeman348
W
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
Brakes ATS brembos and drums
  • 5ptslow
  • Nov 16, 2025
Fox 5.0 Mustang Tech Apr 4, 2026
AeroCoupe
