Max A/C and turn signal problem
DebnDen
Pensacola, FL
Sometimes when I start my car the max a/c and turn signals won't work, the other air/heat functions work just fine. Then sometimes, depending on how long I drive, all the warning lights will flash on and then the max a/c starts blowing again. Then other times I'll start the car and everything works with no problem. Does anyone have an idea of what the problem could be?
No info about your car's model year, EFI or carb, no mods listed. Makes it hard to troubleshoot when we don't know what you have.
Therefore, no clue as to which wiring diagram you need. The wiring changed several times between 79 & 95.
That's why it is a good idea to use the sig under the user control panel (User CP) option. It allows you to post your car year & mods, which help greatly when troubleshooting things. No, it is not there for us to snoop and see any "Secrets" you have hidden away under the hood. Be a good stangnetter and update you sig for future reference & don't keep us guessing.
