  • SN95 4.6L Mustang Tech
max spray
  • Thread starter Thread starter hammertime99
  • Start date Start date Sep 18, 2007
H
hammertime99
coplay pa
Sep 18, 2007
  • Sep 18, 2007
Does anyone know what size shot of nitrous a stock block 2V can handle?
04YELLOWGT
1,135
Indiana
Sep 18, 2007
  • Sep 18, 2007
Some say 150shot but I know people that have/do run nitrous and a few have burnt a piston on the 150shot. I always say 100 just to be on the safe side.
the98stang
2,408
Clovis, CA
Sep 18, 2007
  • Sep 18, 2007
125 is pushing it. 150 is asking for trouble. 100 shot is just right
04GTMustang
348
Stafford
Sep 18, 2007
  • Sep 18, 2007
UPS delivered my NX plate kit today and i too will be spraying a 100. 150 is a bit much on a stock bottom end. if you spray a 150 be sure to get it tune.
I am starting on the 50 shot then moving up to the 100
H
hammertime99
coplay pa
Sep 18, 2007
  • Sep 18, 2007
Thanks 100 should do for a while till I get bored again and spray the piss out of it till something explodes. A 351 would be nice anyway.
Bad Karma
24
Eastern NC
Sep 20, 2007
  • Sep 20, 2007
150 isnt as dangerous as they say. IF
I had the plate kit and sprayed 150 for a long time.
Get some NGK tr6s
pull 6 degrees of timing
Drive like you have sense and dont be a ricer and spray it everywhere you go. (spray to the grocery store)
go run some 11s!!!
Nitrous express will back me up on stock fuel system and block holding 150.
Stan Weiss
347
Philadelphia, PA
Sep 20, 2007
  • Sep 20, 2007
Burning a piston has nothing to do with the size of the shot and everything to to with the tune / fuel delivery. If it does not have the right A/F ratio on a 50 shot it will burn a piston.
the98stang
2,408
Clovis, CA
Sep 20, 2007
  • Sep 20, 2007
Get some NGK tr6s
go run some 11s!!!
Like I said, it's a gamble. Your one of the lucky ones. There are many other people out there that have had bad luck. It's not worth the risk to me...
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Sep 20, 2007
  • Sep 20, 2007
In my opinion a 150 shot is pushing it for someone that wants reliability to be at the forefront.
The block can take way more than a 150 shot.
The problem is the piston and rod make-up.
A tune is crucial.
DoubleONegative
1,528
Tioga Cty PA
Sep 20, 2007
#10
  • Sep 20, 2007
  • #10
5spd GT said:
A tune is crucial.
What he said
also...Dry shot= Bad, Wet Shot= good...just make sure you get a all the proper equipment IE: window switch
C
CENTENNIALSTANG
Houston
Sep 21, 2007
#11
  • Sep 21, 2007
  • #11
Get some NGK tr6s
go run some 11s!!!
I sprayed mine everywear 125 shot broke my car i went threw 25lbs a week for 2 months with a tune/tr6s/pulled timing. I think my fuel pump just went to crap. But im a ricer
Fox Goonies car
  • keel
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
keel
identifying smog/fuel part on 1998 GT
  • dochawk
  • Jun 18, 2026
SN95 4.6L Mustang Tech Jun 30, 2026
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
F
Putting 1991 Hatch on 1986 Car - What Size/Thread Hinge Bolts?
  • frwgt350net
  • Jun 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
Mcmahst
Engine What’s that?
  • PonyGTrider
  • Aug 24, 2026
Fox 5.0 Mustang Tech Aug 25, 2026
PonyGTrider
