Maximum compression on pump gas?
  • Thread starter Thread starter X302LX90X
  • Start date Start date Apr 29, 2007
X302LX90X
29
  • Apr 29, 2007
I was thinking of building a high compression bottom end. I was thinking I could still be safe with 11.5:1 and still run 93 octane. If not I will have to change my combination.
12Pack
46
CT
Apr 29, 2007
  • Apr 29, 2007
http://bestnetpostcards.com/funvideo.html
I had 12:1 on my 87gt and it ran fine on 93. So i think your safe..
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Apr 29, 2007
  • Apr 29, 2007
It depends largely on your camshaft and how it relates to the dynamic compression. Most will give you there static compression, but dynamic is the most important when it comes to compression and running 'pump gas'...
Dynamic compression in a nut shell is the compression once the intake valve closes...
gcwh02
515
pottstown, PA
Apr 29, 2007
  • Apr 29, 2007
12:1 on pump gas here
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 29, 2007
  • Apr 29, 2007
yes I would think you should be safe with that compression.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
393W Stroker with Boost - Need Spark Plug Recommendations
  • 387lx
  • Apr 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 30, 2026
HotFox
