Maximum Horsepower?
KBCobra95
356
North Carolina
Right now I have Afr 165 Heads, Crane 2031 cam, T-Moss ported lower, and a Kenne Bell Blowzilla/ Flowzilla supercharger. What is the Maximum Wheel horespower I can go. Was wanting atleast 400-425 rwhp. Is this possible on the stock bottom end? Will I need a Main girdle? Thanks Andrew.
400-425 is fine on the stock bottom end ( to a point ) depends on how are you are on it as well.
Best way to prevent motor failure is to get a tune then it will run safe w/ no worries and you get your HP #'s insted of just guessing at what your getting.
Swarzkopf said:
Can you really reach 400+ RWHP with a stock (if ported) intake manifold? Wouldn't swapping to ANY aftermarket manifold afford a big horsepower gain here?
i think hes using a cobra lower with his KB
if the intake is ported and heads flow well enough i dont see why you cant make 400's
