I have the one piece aluminium drive shaft and wanted to measure pinion angle. Only change to suspension has been the rear roush springs. Let me know if I'm doing this correctly.
I may be wrong, but, I'm pretty sure that your differential pinion and transmission shaft should be in the same parallel plane. If they aren't, you could adjust the tailshaft with shims or rear axle links (provided they have adjustment capability).
Parallel plane? Didi I say that right? Heck, just imagine that the shafts are both guns that shoot a bullet for an infinite distance with no drop, the bullets would never cross paths.
Please mention why you are doing this as pinion angles have not been a known problem on this car.
This is how you do it:
1-Add weight to get the car at design height.
2-Measure pinion flange face.
3-Measure trans output shaft
Compare to factory specs.
The driveshaft is not normally measured.
I used to work onm driveline issues on the Mustang- we did have angle problems on the old Miustang but not on the present one. Good luck
What overall negative affects will this have? I plan on taking it back to have them install correctly,just not sure of what damage might be already done?
