Mechanical temp guage
1993splash
Hey guys. I dont have a mustang but I do have a 93' 2.3 ranger. I was wondering if anyone has installed a aftermarket temp guage on their 2.3. I cant find an empty plug in the block to put it in. Anyone have any advice? Thanks, Kamran
Since the factory gauges are crap, I put my sender right in the side of the block where factory hole is.
Some people don't like the factory gauges unhooked but if they don't mean anything, why not?
I use mechanical oil and water temp
Is the stock sensor on the driver side low on the block? Our engines might have some small differences but should be similar. Did it make your check engine light go on? thanks,Kamran
leave the stock one hooked up. how else is the computer going to know when the motor warms up? it'll get stuck in "warm up loop" with a high RPM idle... You can get a T fitting onto the heater core feed hose and do it that way...
