mechanical to electric speedo question
Generally, you replace the speedo cable with the sending unit. You can use the vehicle speed sensor (VSS) from a '94-5 T-5 (that's what I used - may be applicable to other years as well) to drive your electronic speedo. The sensor has a pass-through for a speedo cable, so you could actually use both if you wanted. I capped off the speedo cable opening and just use the speed signal (simple 2-wire connection).
