Melbourne area stangs
Originally posted by erichmess_
Bag...what size rims do I have (yeah, pathetic, I should know) I mean, I know they're 17's, but are they 8 or 8.5? White and I need to know...since they're the rims we're gonna put on the SVO's (freakish, I know)
I believe they're 8's. All the ones I've seen in factory size were anyways.
Originally posted by Hawk1340
K here is how it works
n2o goes from bottle to ZEX box, this box has a solenoid in it and a PC board that has a WOT sensor. Only activates at WOT.
I added the NOS proshot so I spray fuel as well as n2o, making it a Wet kit. MUCH safer no chance to lean out.
When switch is on, and I go WOT I spray both fuel and n2o, I added a relay to protect the ZEX box, hence the extra wires.
I can add a wiring diagram if needed.
If you are looking to install a n2o kit I HIGHLY suggest a WET kit, much safer.
Alright, I think I got it. No diagram necessary, but thanks for offering. :D I'm going to look into it one day when I get the SVO. Should be pretty cool. Thanks for the info. :cool:
Originally posted by White93'LX2.3
that doesnt sound too complicated! and im probably gonna put like a 100-150 shot on my svo! but gotta get the car first!:D
75 shot will be good enough to spool the turbo. Need to check out Joe Morgan's Pinto information as he pretty much used nitrous to spool the turbo off the line.
if you're looking for something noncomplicated you could always run it dry ... just directly hook it up to your intake ... and you're done (kinda) ...
Man, I wasn't going to go any higher than 75 or so. 100+ on a turbo 4 might be a bit much, I think. But then again, I'm not the expert.
ok so ill only put a 75 shot on it! im still learning! what if i put a bigger turbo on it!??:shrug:
still should do enough...plus you'll proably be sizing the turbine wheel to your engine and making sure the compressor wheel isn't too big for the turbine wheel.
