Memory has failed
  • Thread starter Thread starter nightrider50
  • Start date Start date Apr 24, 2010
N
nightrider50
186
California
Apr 24, 2010
  • Apr 24, 2010
Putting back together the lower intake. I remember everything except one hole that is just a mystery. The black water/coolant tube that goes from the water pump to the heater, and back into the front of the lower intake... there is a bracket near the back of it that goes down onto the intake manifold. The tube is #29 in this picture.
http://www.allfordmustangs.com/forums/attachments/5-0l-talk/79050d1253245675-just-purchased-1990-mustang-5-0-convertible-several-questions-0900c152800694f9.gif
From all the pictures I have seen it looks like a bolt just goes down into that hole to hold the tube in place. But the hole on my intake (trick flow) is not threaded and I have no clue how it was before i took this thing apart. Any help on this would be amazing!
SScott
Powered by LORD
Apr 23, 2004
304
Alabama
Apr 24, 2010
  • Apr 24, 2010
Maybe it was not bolted down before? If that's the case, and you already bolted on the intake and don't want to get out the tap set, then you can get some of those nylon push in holders from the help section at Autozone, you know the ones that hold the bumper and interior parts on.
cjrpony
439
West Michigan
Apr 24, 2010
  • Apr 24, 2010
There should be an intake manifold bolt in that hole. The bolt for that hole has a stud on top of it that the bracket goes on and is held down with a nut. You will probably have to go to the junk yard to get one if you have lost yours, I don't think you can buy these at the parts store.
L
Lawbreaker5.0
543
Texas
Apr 24, 2010
  • Apr 24, 2010
Wait there's a hole? There should be twelve lower intake bolts, two that have studs on them. One goes on the back right bolt and the other one goes on the 2nd to last bolt on the left side, which holds the coolant tube in place. If you just put a regular bolt in the place, i highly doubt the coolant tube will move around.
cjrpony
439
West Michigan
Apr 24, 2010
  • Apr 24, 2010
Right, after the hoses are hooked up and the tube is screwed into its fitting, it is not going to go anywhere.
N
nightrider50
186
California
Apr 24, 2010
  • Apr 24, 2010
Thanks for the replies guys. All it took was a stronger flashlight and a cup of coffee to realize that i'm an idiot and there were threads way down there. Picked up a regular bolt and got it back together.
L
Lawbreaker5.0
543
Texas
Apr 25, 2010
  • Apr 25, 2010
I just wonder how you did the torque sequence without that bolt? That would have been the obvious clue. Or maybe you haven't torque em yet?
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
  • dan50
  • Jul 18, 2026
dan50
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
T
Convertible A-pillar weatherstrip issues
  • thiefofcheese
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 20, 2025
AeroCoupe
