  • SN95 4.6L Mustang Tech
Methanol Injection?
  • Thread starter Thread starter speedfreak98r
  • Start date Start date Feb 23, 2006
speedfreak98r
Banned
Jan 31, 2006
Houston Area
Feb 23, 2006
  • Feb 23, 2006
I have an N/A 4.6. What exactly does methenol injection do? I've heard of the blown cars using it to cool the boost charge, but could I use it on my n/a 4.6? If so, what kind of gains would I get? Would I have to modify the engine?
USMstang
114
Mississippi Gulf Coast
Feb 23, 2006
  • Feb 23, 2006
http://forums.stangnet.com/showthread.php?t=616512&highlight=water+injection
If that doesn't answer you questions, do a search in the 4.6 Tech section for " water injection"
jstreet0204
939
Winston Salem, NC
Feb 23, 2006
  • Feb 23, 2006
Water Meth injection will not make much if any power alone. It will allow you to run more timing with less octane, but unless you have a very high compression engine, you aren't going to see much gain on a n/a engine.
1ba96gt
181
  • Feb 23, 2006
Like he said is generally used on FI cars. Cools intake temps, and does some other things I don't have the knowledge to talk about in depth about. It does increase heat in the cyclinder though once it starts to burn. I have watched someone spray it, have too much methanol in the mix and burn all 8 plugs. That was on a pretty experimental combination though.
Cliff Notes: Not worth the money on a bolt on car.
USMstang
114
Feb 23, 2006
  • Feb 23, 2006
It would not be a good idea to mix more than 50/50 water to methanol.
reeber
574
26
38
Berlin, NJ
Feb 23, 2006
  • Feb 23, 2006
methanol injection is only used for cars that have higher than normal intake air temperatures. The only benefit to having methanol injection is to cool the air entering the intake. This is done by atomizing the methanol mixture with the air mixture, creating a cooler air charge, giving you the ability to increase timing due to the safer, cooler air. It pretty much does the same thing an intercooler does for a blower / turbo. So, no, N/A cars do not benefit from this...
USMstang
114
Feb 23, 2006
  • Feb 23, 2006
That was a pretty liberal use of the word "only". If you are looking for big horsepower gains, this is not for you on a N/A car. If you are looking for other benefits such as being able to run advanced timing and not paying 20 cents a gallon more for gas, then you do the math and it may be beneficial to you.
EDGE Motorsport
561
Saleen S281, London, UK
Feb 23, 2006
  • Feb 23, 2006
im running the snow kit on mine (9psi paxton) and it dropped my intake air temperature from 190*F down to 64*F.... that is an astonishing difference.. allowed more timing and less fuel and therefore more power
on a very high compression NA build, you would use it as a means to cool the air and so be less likely to detonate. However, you'd need to be running a serious NA build to require intake cooling to that level.
EDGE
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
L
5.4 4v base ignition timing table help.
  • leoleo
  • Aug 16, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 17, 2026
MustangBetts
M
Resolved Holley terminator integration into CCRM
  • BrandonMP
  • Feb 25, 2026
SN95 4.6L Mustang Tech Aug 23, 2026
fasterthangas
F
Fox Fuel injection questions
  • limp
  • Jul 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Monday at 4:14 PM
AeroCoupe
J
Timing cover for npi 4.6
  • jay99914
  • Oct 26, 2024
SN95 4.6L Mustang Tech Oct 28, 2024
jay99914
J
