Might be getting a 390...
  • Thread starter Thread starter skywalker
  • Start date Start date May 29, 2004
1 of 2 Next Last
skywalker
733
Pensacola, FL
May 29, 2004
  • May 29, 2004
A guy offered me a full 390, currently disassembled for basically nothing today. If it works out (as in, he doesn't change his mind) what should I do with it? Should I sell it, or swap it into my '68 coupe? Any ideas?
Route666
1,652
Brisbane, Australia
May 29, 2004
  • May 29, 2004
Rebuild and sell is what I'd do. I don't have any real affections for any kind of motor. I'd rather sell it and spend the money on a lighter 302, with 331 stroker, etc.
skywalker
733
Pensacola, FL
May 29, 2004
  • May 29, 2004
Doesn't need a build...just needs to be assembled...that's the beauty of it.
I don't have particular effections either, but I know it will fit in my '68, can be stroked, and could make alot of power over my 289.
Route666
1,652
Brisbane, Australia
May 29, 2004
  • May 29, 2004
Even better then.
LMan
1,246
Mom's basement
May 29, 2004
  • May 29, 2004
Id either pass on it or sell it pronto.
To put it in your car, youd need new exh manifolds and exh hookup, motor mounts, all new accessory bracketry, radiator considerations, plugs are a b*tch to change, the list goes on. All for a motor that stock, weighs at least 150-175 lbs more than your current motor and one a hot 289 would beat in the 1/4 darn near every time.
Did I mention the extra weight wont help your handling?
If you want a stroker, stroke what you have (so to speak ). JMO.
skywalker
733
Pensacola, FL
May 30, 2004
  • May 30, 2004
How much would it go for then?
jerry S
1,365
52.22N 5.12E
May 30, 2004
  • May 30, 2004
if it were I in your place
I would stroke it to 427. That way, you'd have a true BB 427 and not a SB with negative rod ratios. That's just me, what I'd do in your place.
R
Ronstang
1,294
Houston Texas
May 30, 2004
  • May 30, 2004
You might be able to stroke a 390 to a 427 (I do not know though) but it would not be a true 427 since the bore on a real 427 was larger and there is not enough room in a 390 block for that kind of overbore.....IIRC that is.
skywalker
733
Pensacola, FL
May 30, 2004
  • May 30, 2004
But wouldn't a stroked, hot 390 beat the crap out of a hot 289 on the the 1320?
skywalker
733
Pensacola, FL
May 30, 2004
#10
  • May 30, 2004
  • #10
You can stroke it further than 427 actually...though I don't think I'd go further than that. Ronstang, what are you thoughts on the whole matter?
D
D.Hearne
11,730
south louisiana
May 30, 2004
#11
  • May 30, 2004
  • #11
Even a stock 390 would beat a 289 provided you had the traction to keep the tires from going up in smoke. I had a stock 67 fastback 390 Stang that had a 3 speed Toploader, 3.00 geared 9 inch ( open diff) It would run low 14's just the way it was. Another plus is the look the other guy gives when you pop the hood. Nothin like a big block to get peoples attention. You don't need to stroke a 390, just give it a healthy cam,a 10 to 1 comp ratio, a little pocket porting, a set of FPA headers, a 428PI intake, 750 Holley and you've got all the power you'll need. You can spend the money you'll have left over for motor mounts, and stiffer springs. And for the guy who posted that big block Stangs can't be made to handle, I can say from experience, that you're dead wrong.
67GTA-FB429
777
Tri-Cities, Wa
May 30, 2004
#12
  • May 30, 2004
  • #12
BIG BLOCK, baby. More CIs the better.
skywalker
733
Pensacola, FL
May 30, 2004
#13
  • May 30, 2004
  • #13
I agree. I already have 620s, so I can't imagine I need to get much stiffer than that...at least not for my purposes (hi performance street machine mostly...) I'm just wondering if in the long run I might be better to sell it to get something better. Since it is already disassembled, and it wouldn't get installed for awhile, why not stroke it now?
67GTA-FB429
777
Tri-Cities, Wa
May 30, 2004
#14
  • May 30, 2004
  • #14
Stroke and bore. 10:1 pistons, port and polish heads, roller valvetrain. You are set, you will have more torque and HP than you know what to do with.
skywalker
733
Pensacola, FL
May 30, 2004
#15
  • May 30, 2004
  • #15
Not to mention I could use some of those crane roller lifters that allow you to use any standard roller camshaft...
D
D.Hearne
11,730
south louisiana
May 30, 2004
#16
  • May 30, 2004
  • #16
If you have the $$ to go stroker, then go for it. But having run several 390's, I can tell you, that in a Stang, it's not really necessary. Spend the $$ on a roller cam and valve train. And the FPA headers ( $400)
LMan
1,246
Mom's basement
May 30, 2004
#17
  • May 30, 2004
  • #17
...but that's not what I said
SandSprite
332
L.A., CA
May 30, 2004
#18
  • May 30, 2004
  • #18
IIRC, I think you can only stroke a 360/390 to 410 by using a 428 crank. I don't think you can bore it enough to get 427/428. Could be wrong though.
My 2 cents is to keep a small block. Is that T5 really gonna work behind a FE? By the time you're done upgrading the drivetrain and the 390, you could have made the 289 really nice. Also, you will have some "downtime" while swapping, 'cause we all know things never go perfectly.
Then again, this is all "what-if?"-- you don't even know if you're getting it yet.
skywalker
733
Pensacola, FL
May 30, 2004
#19
  • May 30, 2004
  • #19
True. I'm supposed to find out tomorrow. If I kept it, it wouldn't be a short term project...I wouldn't evens tart on it until probably october.
jerry S
1,365
52.22N 5.12E
Jun 1, 2004
#20
  • Jun 1, 2004
  • #20
have a look-see here for a 390 bored and stroked to a 428 ci 525 hp monster:
http://www.proformanceunlimited.com/specs/428_525HP_AAL.html
1 of 2 Next Last
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
P
rear Impact absorbers.
  • Praetorious
  • May 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2026
Praetorious
P
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
R
Fox Foxbody Notchback Coupe 1979
  • robrouck
  • Apr 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 20, 2026
slow84lx
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
