MIL eliminator not working????
99prmustang
141
i jsut installed my mil's from mileliminators.com and me SES light is still on? i double check all the wiring and it seemed right. does it take a few days for it to register? is there anything else that i have to do? or do they jsut suck and not work lol?
try switching them from side to side, i know it sounds stupid but, one of my buddies called the manufacturer of his & they told him to do it. he went & did it the next day & viola..... no more light. & if that doesn't work, most likely you have a bad FRONT o2 sensor :nice:
Try contacting the vendor and let them help you. If they sucked, I doubt 2000 Mustang owners would have purchased them last year.
Email us or give us a call and we'll help you troubleshoot after you scan the codes. We need the codes to troubleshoot your issue effectively.
In the meantime, read this:
http://www.ponyexpressperformance.com/MILtech.html
Let me summarize the link for everyone else:
We ask this for a couple of reasons:
There are 100's of variables that could trigger your "check engine" or "service engine soon" light when running an offroad H or X pipe, or gutted stock cats. Let's break down some of the possible installation errors that will cause the MIL Eliminators not to properly keep your "check engine" or "SES" light off after the MIL Eliminators are installed.
Damaged Rear O2 sensor - MIL Eliminators need a healthy O2 sensor signal to work properly.
Incorrect Wiring in of the MIL Eliminator(s).
Rear O2 sensor(s) not properly torqued to spec. in exhaust pipe.
Rear O2 sensor connector not properly plugged in to wiring harness.
Exhaust Leak at the front flange between exhaust manifold or header and offroad pipe.
Front O2 sensor(s) damaged during swap from stock catted exhaust pipe to offroad pipe.
Front O2 sensor(s) not properly torqued to spec. in exhaust pipe.
Front O2 sensor connector not properly plugged into wiring harness.
Was the battery unhooked to reset the PCM (Powertrain Control Module or Computer) before the installation began?
As the installer can see, we have to narrow down the above variables and pinpoint the specific issue before a judgement can be made on whether or not the MIL Eliminators are truly faulty and need to be warrantied. This is precisely why we ask each customer with issues to scan or have scanned the trouble codes before we can make an educated decision on whether or not to warranty the product. 99.99 percent of MIL Eliminator install concerns are due to other variables besides the MIL Eliminators themselves, so pull the codes and write down the actual code numbers before emailing or contacting us for assistance or warranty.
Without the DTC's, we can't be of much help, and won't warranty the product unless we know for sure the MIL Eliminators are at fault. The DTC's will help us make that educated decision. Pull the codes and help us help you.
Thus the reason why we need the code numbers, not descriptions.
Unhook your battery for 10 mins to reset the computer and it will go off. If it comes back on you were correct it needs to be driven around awhile to fully register. same happened to mine on my 96 cobra. when installed it went off and then came back on and i thought it was a scam but i drove it around and i'd say 1000 miles later it went away never to be seen again
