Milky oil
sixtyfive
157
Was working on my oil leak which was likely coming from the front of the engine between the oil pan and the block. When I went to check my oil I noticed that it had a white milky look to it, this was present after letting the engine run til it got to operating temp.
The engine is under 2 years old and has not seen much driving, it is a 347 (stroked 302) which was professionally built. The vehicle runs fine but I think that this is a sign that I have a bad head gasket? I am not sure, but I took a video of it and would love any info you guys can give me.
First of all my antifreeze in the radiator is the perfect color of green. I also checked my oil again, it appears normal so whatever it was has settled. So I think that doing a compression test would be a good idea just in case, hopefully this is just a scare and not a big problem.
Also I wanted to check to make sure my intake/valvecovers and a few other things are tight, but my engine has some weird bolts on the intake and valve covers and I need to get a tool for it, they look like either a torx with way more points or something else. I took a video of them since I did not have my camera on me. Can anyone ideintify them?
Should be a 12 point socket...Im also going to agree with the condensation getting into the oil. I would change the oil and run it and see if it gets milky again.
