min vacuum required for the EEC
  • Thread starter Thread starter 90stang5speed
  • Start date Start date Jun 16, 2009
9
90stang5speed
582
Columbus Ga
Jun 16, 2009
  • Jun 16, 2009
Is there a minimum amount of vacuum that the EEC needs to see on a 90 mustang? the reason for this question is, I am planing on swaping out the 302 & replacing it with a 557. I want to keep it fuel injected and use the factory A9L eec to control it. I have the TWEECER RT so i know I can change things like engine size, firing order and MAF & injector size. I am working with Lem Evans on cam selection for the big block. He asked what the min vacuum requirement was for the EFI system that I will be running. All I could tell him was that curently, I have a 302 with an f303 cam that pulls 14 to 15 lbs of vac at idle and all vac lines are plugged off except fuel pressure reg & brake booster. I told him that i have a MAF instead of a MAP sensor and the car is not equipped with a nock sensor but, I dont know if there is a min vac requirement. any help with this would be great. Thanks
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 16, 2009
  • Jun 16, 2009
The Mass Air computers used on 5.0 Mustangs do not have a vacuum sensor or a knock sensor.
The amount of vacuum becomes an issue with street driven cars and the power brake booster. If your power brakes are good with 14"-15" of vacuum, then you probably won't have any problems with a new engine.
9
90stang5speed
582
Columbus Ga
Jun 16, 2009
  • Jun 16, 2009
thanks for the info
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jun 16, 2009
  • Jun 16, 2009
You have to do a project thread of that beast!
9
90stang5speed
582
Columbus Ga
Jun 16, 2009
  • Jun 16, 2009
I would like to post up info on the build but it wont actually begin coming together until about this time next year. once I move to georgia and get my bonus, i will have the funds to build the 557. no dought it will be a monster.
  • dan50
  • Jul 18, 2026
dan50
Engine 91 5.0, Vacuum Line Connected to BAP Sensor??????
  • sscobra
  • Aug 31, 2023
2K
Fox 5.0 Mustang Tech Sep 1, 2023
General karthief
A9L on 94 engine, no priming injector pulse?
  • Wallyman
  • Jun 17, 2024
  • Other Auto Tech
2K
Other Auto Tech Jun 24, 2024
Wallyman
J
*New guy* Microsquirt questions regarding required engine info.
  • jack.stand.racing
  • Sep 23, 2020
  • Digital Self-tuning Forum
3K
Digital Self-tuning Forum Sep 24, 2020
jack.stand.racing
J
A
Engine 93 Mustang - Low Vacuum at idle
  • Ant01n3
  • Jun 22, 2018
Fox 5.0 Mustang Tech Jun 22, 2018
Ant01n3
A
